Old 10-23-2013, 02:42 AM   #1
Chrisxeasy
Chrisxeasy's Avatar
Smile Lowered 75 C10 long bed
Finally convinced myself to get a start on this monster! First off its a 75 with 81k original miles. Motor is a 350 with auto trans.
To start off I started with replacing the body panels that were rusted out, and added a rear axle flip kit and 1.5" off springs in front.
Next up is my 2.5" drop spindles and shocks from Lmc and rear shackle set with c-notch on the rear.
I am in trouble when it comes to my cab repair panels, without knowledge of welding and how exactly these are replaced. My most important task before paint.
And I am wanting to fit 22s possibly 24s depending in how wide I can go, and how low.
Anything thoughts? Please share
Last edited by Chrisxeasy; 10-23-2013 at 02:44 AM. Reason: Adding description to title
Chrisxeasy is offline   Reply With Quote
Old 10-23-2013, 02:43 AM   #2
Chrisxeasy
Chrisxeasy's Avatar
Re: Lowered 75 C10
And another
Old 10-23-2013, 07:41 AM   #3
Rascal_one2001
Rascal_one2001's Avatar
Re: Lowered 75 C10 long bed
looks like a good start I like the factory white and green two tone with white top. looks like you may have some camber issues on the driver front. from the pictures it mostly looks like rocker panels that need work and you don't have to be a good welder to spot weld just take your time drill the factory spot welds pull the old one put on the new and re spot weld after double checking placement a hundred times.
1985 1500 454, 4l80e, 12 bolt, 5/6 drop, 20s
Rascal_one2001 is offline   Reply With Quote
Old 10-23-2013, 09:04 AM   #4
77ChevySharkBite
77ChevySharkBite's Avatar
Welcome to the Forum!!
Looks like a good start to be a great truck! Enjoy the truck there a blast.
My only other comment to add about welding is if your very unsure of your welding skills before you try and tackle it on your trust made do some practice testing, just so that you're more comfortable with it.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 10-23-2013, 12:48 PM   #5
Chrisxeasy
Chrisxeasy's Avatar
Lower rocker panel rust to replace
Old 10-23-2013, 01:04 PM   #6
Chrisxeasy
Chrisxeasy's Avatar
Thanks! There is a little camber on the front, heard control arms would bring that out? Also heard spindles would too. Not quite sure!
Old 10-23-2013, 02:50 PM   #7
tinydb84
tinydb84's Avatar
You need to go get an alignment. They will add shims to the upper arm to correct it.
You could get narrower lower arms. Spindles wont correct it but just lower it more. If you put the original springs back in and did spindles then you wouldn't have the camber issue.
David
Instagram: myfabguy
Old 10-23-2013, 04:21 PM   #8
rusty76
rusty76's Avatar
Good looking truck. I like the paint scheme and I also like the thin whites. I'm old school....lol. I've got my fair share of rust to tackle but you can do it or find somebody willing to help.. Good luck.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-03-2013, 12:08 PM   #9
Old School Low
Old School Low's Avatar
Did u have to notch when u flipped leafs? If not, will for sure huh w shackles?
Old School Low is offline   Reply With Quote
Old 12-04-2013, 01:22 AM   #10
Chrisxeasy
Chrisxeasy's Avatar
I just did an axle flip kit and was fine without flipping, then I did a c notch and shackles, definitely needed to notch for the 2 inch drop shackles
Old 12-05-2013, 11:22 AM   #11
muffintop
got any pictures of the axel flip?
muffintop is offline   Reply With Quote
Old 12-08-2013, 12:44 AM   #12
Chrisxeasy
Chrisxeasy's Avatar
Here is before c notch which wasn't too hard at all
Old 12-08-2013, 12:44 AM   #13
Chrisxeasy
Chrisxeasy's Avatar
C notch in
Old 12-08-2013, 12:45 AM   #14
Chrisxeasy
Chrisxeasy's Avatar
2 inch shackles
Old 12-08-2013, 01:43 AM   #15
Old School Low
Very good pictures, thank u. Who'd u buy notch plate from? Maybe u made it? Think ill flip first like u. Dont know what the notch kit costs but looks like welder neighbor could fab me one up. Flip kit is just u bolts and some kind of axel pad? Thanks again. (trying to send som pics but been waiting 10 min? to upload. ill try again later
Old 12-08-2013, 10:15 AM   #16
baclay9
Not sure if it matters but I am pretty sure your shackle is on backwards. Nice progress!
baclay9 is offline   Reply With Quote
Old 02-01-2016, 01:58 AM   #17
Hyperbatix
Any more progress? You have a similar truck to mine, and I'm just about to get started on my project. Great pics!
Hyperbatix is offline   Reply With Quote
