Old 10-23-2013, 10:15 AM   #1
KrazyRay
KrazyRay's Avatar
Rear Shock Relocators 87 1/2 ton 2wd
I just finished doing the rear axle flip on my 87 GMC and I'm having a hard time finding a vendor who sells shock relocators. Also, I plan on using air shocks for towing and I'm wondering if I should fab up some brackets in a different location to straighten up the angle of the shocks between the axle and the frame. Any help is appreciated!
Thanks,
Ray
KrazyRay is offline   Reply With Quote
Old 10-23-2013, 11:10 AM   #2
Jonboy
Slots go on anything!
Re: Rear Shock Relocators 87 1/2 ton 2wd
I bought the last set from Summit, but have purchased them from CPP as well.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 10-23-2013, 03:58 PM   #3
rudey737
I think these are recommended quite a bit on the board.
http://www.summitracing.com/parts/ws...olet/model/c10
I was hoping to get some McGaughy's relocation brackets to go with my McGaughy's 4.5/6 drop kit - I'm a little OCD - but I think I'm just going to buy these. They're about $20 cheaper than the McGaughy's brackets I've seen.
Azulita - 84 Chevy Scottsdale Longbed 305/350
rudey737 is offline   Reply With Quote
Old 11-06-2013, 11:47 AM   #4
KrazyRay
KrazyRay's Avatar
Thanks for the link. Those extenders will work good. I measured the shock bolt and its 9/16" diameter. I found some air shocks at summit MA728 Monroe that are 5/8" diameter with a 14 1/4"- 23" range. Are the 5/8" the proper shocks to get?
Old 11-07-2013, 11:10 AM   #5
blazer2007
I had air shocks on mine and they would not pump up on such an angle so try and get them close to the way they were,I guess they were trying to push my axle away instead of up
blazer2007 is offline   Reply With Quote
