Old 10-23-2013, 04:54 PM   #1
Pablo22
Carburetor Fuel Inlet Stripped
The threads in my Carb are stripped where the fuel line attaches. I took it to a Carb shop and was told to just get a Deeper Fitting since only the first three threads are stripped. NAPA couldn't find anything nor could J&M Speed Shop. Anybody have any ideas? I'm in Riverside, CA. Thanks.
Pablo22 is offline   Reply With Quote
Old 10-23-2013, 05:50 PM   #2
63burban
Chevy addict
Re: Carburetor Fuel Inlet Stripped
What carburetor are you using ?
63burban is offline   Reply With Quote
Old 10-23-2013, 07:19 PM   #3
Pablo22
It's the stock Rochester on the 230.
Old 10-23-2013, 08:28 PM   #4
1966shortwide
IF this is the fuel filter housing fitting going into carb, cheapest way is to coat thread's on adaptor with jb weld and leave filter out . install a inline filter in the fuel line . i use regular jb weld ,not the quick set. Then you won't have to remove that fitting for any reason by leaving the filter out.Otherwise a different carb or top half. If you do this it has to set up overnight or a certain amount of time on instruction's on jb weld. I have done this before , and it is gas resistant.
1966shortwide is offline   Reply With Quote
Old 10-24-2013, 08:29 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Any epoxy or Teflon tape you use will eventually degrade with the gasoline. I'd look for an oversize kit, heli coil or other type of repair. Maybe take it to a machine shop and have them machine the threads to the next size if carb hasn't had this done before. http://quadrajetparts.com/fuel-inlets-a-1.html
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
