Old 10-24-2013, 03:39 PM   #1
Hook'em
Hook'em's Avatar
Tricks for removing bench seat?
I have a full set of replacement seat belts on order and I doubt that I can get the old ones out and the new ones in without removing the stock bench seat. With that being said, every time I try to do something on the truck it turns out to be harder than I anticipate - I already anticipate the task to be a pain.
Are there any tricks to removing the bench seat?
Hook'em
Hook'em is offline   Reply With Quote
Old 10-24-2013, 03:43 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Tricks for removing bench seat?
Remove bolts. Remove seat. Very easy and straight forward. May need PB blaster or some other penetrating oil to remove the seatbelt bolts, they can be a pita sometimes.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 10-24-2013, 03:59 PM   #3
ksshane
ksshane's Avatar
Band aid and a shot of jack incase you bust a knuckle... actually the shot of jack has multiple uses... you may want it for after you remove the seat for a job well done.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 10-24-2013, 04:33 PM   #4
Davis53
Davis53's Avatar
Should be no problem, go out the passenger side with it though! I live in the Round Rock!
Davis53 is offline   Reply With Quote
Old 10-24-2013, 04:35 PM   #5
srvivor71
srvivor71's Avatar
Boy can I relate to that! Everything I do ends up being way harder than I expect. But I have replaced the seat belts in mine and agree with what LeddZepp said. It's just a matter of unbolting the seat bolts and then the seat belt bolts. And he is exactly right, they must have used Loc-Tite on the seat belt bolts because they were a mofo to get out. I used a breaker bar on them and it was a battle right up until the last thread on each bolt. I followed their lead and used Loc-Tite when installing the new bolts.
srvivor71 is offline   Reply With Quote
Old 10-24-2013, 04:36 PM   #6
sboris
sboris's Avatar
Might want someone else there for the removal, as not to mangle the paint dragging it out. What zepp said, squirt the bolts ahead of time, shouldn't be an issue.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 10-24-2013, 04:54 PM   #7
Hook'em
Hook'em's Avatar
There are a few other trucks around here, but I don't think I have seen yours around.
Hook'em
Old 10-24-2013, 04:55 PM   #8
Hook'em
Hook'em's Avatar
Thanks for the advice.
Hook'em
Old 10-24-2013, 05:03 PM   #9
TheSeeker
My only tip, is that if you have nice paint, pull some towels out of the closet and wrap the frame bottoms with them, keeps the sharp metal corners from gouging anything on the way out.
TheSeeker is offline   Reply With Quote
Old 10-24-2013, 05:16 PM   #10
zeldman
zeldman's Avatar
I agree.... wrap the frames to keep from scratching the paint, and a set of extra hands make it a lot easier to handle going out and then back in.
gig'em
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 10-24-2013, 06:07 PM   #11
cdowns
cdowns's Avatar
no real need to remove the seat from the cab unless you are of the very rotund variety
Old 10-24-2013, 07:27 PM   #12
swamp rat
swamp rat's Avatar
It will help to have a helper to pull the seat thru the cab, one on each end, although i have done it myself a number of times on a lifted truck, its a pita for me being 5'7" tall.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-24-2013, 07:31 PM   #13
In The Ten Ring
The only thing I have done to my truck (so far) where I needed help was when I removed the bench seat.
I unbolted it, saved the bolts in a container, and had a friend get it from the passenger side as I got it from the driver's side. The seat belt bolts came out easily although I did lose a gas tank bolt head when I was removing that but no biggie. If that happens with the seat belt bolts just message us, you'll be in need of an extration or new bolt head.
I might would take pictures of the way the seat belts overlap each other under the bolt is all.
Good luck!
In The Ten Ring is offline   Reply With Quote
Old 10-24-2013, 09:22 PM   #14
yuccales
yuccales's Avatar
Make sure the seat is all the way forward so the seat track does not become a high speed knife when your knee hits the seat lever while removing said seat! Ouch!
yuccales is online now   Reply With Quote
Old 10-24-2013, 09:29 PM   #15
slow-1
slow-1's Avatar
I find that a strong teenage boy on one end of the seat works best...he just folds his body in half at the waist and walks through the cab carrying his end while I back up with my end.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 10-24-2013, 09:39 PM   #16
leftybass209
leftybass209's Avatar
In case the bolts are tight, hit them with some penetrating oil. It really is straight forward.
leftybass209 is offline   Reply With Quote
Old 10-24-2013, 10:22 PM   #17
swamp rat
swamp rat's Avatar
Oh yea unbolt the front ones with the seat back then slide it forward and remove the rear bolts.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 10-25-2013, 05:18 AM   #18
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have pulled the steering wheel and the floor-mounted shift lever, sometimes.
Old 10-25-2013, 08:33 AM   #19
kcsa75
kcsa75's Avatar
This is the best advice on this thread.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 10-25-2013, 11:22 AM   #20
Madtat
Madtat's Avatar
Not to hijack this thread but this weekend I am installing a stock bench seat and gettin rid of the buckets so i'll just do most of the above in reverse order.
Madtat is offline   Reply With Quote
Old 05-12-2022, 04:38 AM   #21
1972k5blazerman
How did that go as I need to do the same but mine is now covered by bee with carpet so I have no idea where original seat went
1972k5blazerman is offline   Reply With Quote
Old 05-12-2022, 06:00 PM   #22
Bones72Super
Bones72Super's Avatar
If you would like an extra set of hands I'm not that far away at Lake Travis and don't mind helping out. I am going to the C10 Nationals this Saturday but should be available on Sunday
WTB 71-72 Original paint Medium Red hood
WTB 1972 Very nice original Parchment seat belt set
Bones72Super is offline   Reply With Quote
Old 05-12-2022, 06:51 PM   #23
yuccales
yuccales's Avatar
Can you use a toad stabber (awl) from under the cab and push up from the holes?
