#26 |
![]() Join Date: Nov 2012
Re: 69 K-10 Build for Dad
I'm in for this build. Looking great!
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build http://67-72chevytrucks.com/vboard/s...d.php?t=589869 |
#27 |
Boosted Member
Little more progress on the engine. Has a full 05 LS6 top end, including the cam, springs, 243 heads, and super light hollow/sodium filled valves.
![]() Rolled the chassis outside for some photos before 1) It gets cruddy outside 2) The body starts going back on. ![]() ![]() ![]() ![]() ![]()
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
#28 |
Super nice on all accounts, including the shop, the grass, the area with no real close neighbors ect..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#29 |
Boosted Member
Thanks man, I'm definitely blessed.
#30 |
Second Chance Program
Looks perfect!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#31 |
Nice build!!!
1970 Chevy K20 Custom Camper 1996 Chevy Impala SS 2008 Chevy Avalanche LT3 2003 Honda Accord EX 2001 Hewes Redfisher 16 Fighting Lady Yellow Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118 |
#32 |
Boosted Member
Got the engine all buttoned up. Gotta finish up the transmission and transfer case next so I can drop it all in the chassis.
![]() ![]() I decided to go with a 1990 K/5 Blazer fuel tank...for a couple reasons. 1) It has a 31 gallon capacity, and since it's a lifted longbed, the extra size of the tank is a non-issue. 2) Those blazers came with TBI engines, so the tank is already baffled and set up for an in-tank pump. I am just swapping a higher output pump in place of the 12 psi TBI pump. ![]() ![]() Took the stock sender/pump bracket and cut it and welded it last night. The 3/8" feed, i was able to use my 37* AN flare tool and flare a tube nut onto that line. The 5/16" return line was a little trickier, so I cut up a steel JIC fitting and TIG'd it to the return tube. I also welded the evap tube closed, as well as the tank vent. I was planning to rely on the vented fuel tank cap, but I might cut the plug out of the vent and run it after all. ![]() ![]()
#33 |
Boosted Member
Got the fuel pump mounted to the hanger and installed in the tank. Was way easy...almost too easy. That can't be good. lol
![]() ![]() The tank fit perfect in the rear frame rails without having to move the rear crossmember. There's even plenty of room between the tank and the diff...no worried of bottoming out and slamming the tank to the axle. ![]() ![]() ![]() Just had to fab up a crossmember to go in front of the tank to attach the tank hanger straps to. Also started routing the return line to the tank in aluminum hard line. ![]() ![]()
#34 |
Still Learning
I really like the sender modification you did for the fuel pump. I may have to steal this idea.
#35 |
Boosted Member
Finished up running the fuel and brake lines to the rear of the truck, to prep for putting the bed on.
![]() ![]() ![]() The body mount hardware showed up, so I figured why not throw on the bed... ![]() ![]() ![]() ![]() Gave it a bath to get rid of the year+ of grime and crud on it. ![]() Next up, mate the engine/trans/t-case and slam it in the chassis.
#36 |
Looking great!
1970 SWB 2wd C10, Vortec 454/80e, CPP 3/5, slotted mags, patina 1972 K20 Super Cheyenne, Short bed, EFI 396, NV4500, NP208 1970 GTO Judge, heads/cam LS1 & stalled 4L60e |
#37 | |
#38 |
![]() Join Date: May 2007
Moving along pretty fast on this one.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#39 |
![]() Join Date: Dec 2006
Nice project
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#40 |
Boosted Member
Rebuilt the transfer case last weekend, and swapped to the 32 spline input that I needed to mate to the 4L80E. Also pulled the pan off the trans, and cleaned everything up in there...then painted it all.
Got the engine/trans/t-case set in place...kinda/sorta last night. Was bummed to find that the stock 4x4 trans crossmember will not work with an NP241. The front output would be directly in line with the crossmember......so I guess I get to fab one up. ![]() ![]() ![]()
#41 | |
Still Learning
#42 |
Boosted Member
Thanks for the link, mcbassin. I ended up cutting up the stock 205 crossmember a bit and making it fit.
Finally got it all installed and bolted down tight. Was able to measure for driveshafts and get those ordered up. ![]() Got nice on Saturday, so I rolled the cab outside and gave it a bath. Had to wash all the nastiness off of it, from sitting around collecting dust. ![]() Pulled the seats and carpet out, so I could get to the floor. Installing a hi-hump in this low-hump cab. ![]() Plasma cutters rule. ![]() A height comparison between the high and low humps. ![]() Voila. ![]()
#43 |
Killer build
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#44 |
huh the high hump is the same color of the blazer and this just came to me, you took a 4x4 and made it a 2wd and now your taking a 2wd and making it a 4x4.
#45 | |
Boosted Member
Thanks!
#46 |
Ephesians 2:8
Love it, your dad is going to be grinning ear to ear when he's cruising in this. Glad you went this route vs parting/selling it.
72 Suburban making it mine My 79 C10 story 79 C10 LS swap 94 LS swapped Daily Driver Tahoe Limited Instagram - @piersonclassics 83 K20 Farm Truck Build |
#47 |
Boosted Member
Not in chronological order, but here's a couple pics of the t-case rebuild/input shaft swap.
![]() ![]() Picked up some trailblazer SS manifolds ![]() No dice. ![]() ![]() The solution: Planning to weld some pipe to these to get the outlets away from the frame, and then a couple of 2.5" V-bands to connect to the rest of the exhaust. ![]() ![]() ![]() ![]() ![]() Tires also showed up. 33x12.50x15 BFG All-Terrains. I'm planning to have the red factory rally wheels sandblasted and powdercoated silver, to stick to a resto-mod theme.
#48 |
Awesome build. I'd love to put some LS power in my 72 4x4 someday.
Erik 1969 Chevy K20 6.0L/4L80E/NP205 1971 Chevy C30 Cheyenne Longhorn 454/TH400 1979 Chevy K30 dually currently in pieces |
#49 |
Boosted Member
Not much new...collecting parts and trying to stay warm. I'm in the winter funk...need a week off from wrenching to recharge.
The dash and bezel showed up. Dakota Digital VHX. Pretty kickass stuff. ![]() ![]()
#50 |
nice work!
like the dash too
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
