#76 |
Re: 71 4X4 Frame off Restoration
#77 |
Nice work its really coming along. Its too bad I just stumbled across your build. There is a shop in Morgan Hill that specializes in LS swaps. I picked up a custom crossmember that is built well and in less pieces than the Dirty dingo one. The shop is called Pacific Fabrication and the guys there are really cool. I also picked up a custom harness they made that is plug and play. Keep it up this is going to be bad a$$
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
#78 |
I worked on installing the right side floor sheetmetal Saturday. Miss cut the floor patch panel so I have to ordered another peice. welded in the new patch for the bottom of the A pillar and fit the suport peice for the floor suport. I assembled the Dirty Dingo cross member.
#79 |
I was abruptly woke up at 4:30am this morning to a loud nois when I looked out my bedroom window someone had hit my 2012 Ram 3500. this truck was to last me the rest of my life. not sure if it is totaled but the 325i BMW that hit it shoved my truck back 10 ft and the hole right side is now up on the curb. this is the 3rd time in 3 years that 2 new truck have been hit. the last truck I had was hit twice once on the righ and once on the left. I think I have a bad case of bad luck.
#80 |
#81 |
That sucks about your truck! Fortunately(or unfortunately, depending on how you look at it), with the price of a '12 3500 being so high, it probably won't be totaled. Hopefully it will get fixed right.
#82 |
#83 |
looking at it this morning after the sun came up the hole front end is pushed back and the driver door and windshield are affected. the body lines are out of alinement as far back as the rear door.
#84 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Bummer about the accident. I was t-boned about one month ago by a careless driver - dealing with the insurance folks etc. can be a real hassle.
Nice build thread though - good luck with it. Any chance you want to sell the OEM hubs off the Dana 44?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland
#85 |
Ouch!!!!!! Thank goodness that the truck was parked and it wasn't a moving head on. I'd like to hear the explanation of the driver of the Beamer? Bigfoot jumped in front of him or something?
#86 |
I'm not going to part out the Dana 44 I'm keeping it. I'm thinking about build some thing with the front and rear axel.
#87 |
The driver said to the police that he fell asleep driving home. I or the police did not smell alcohol on his breath. the driver was taken to the hospital with head injuries.
#88 |
Where's my beer?
Ouch! while the truck may not be totaled, I'd bet money the BMW is. Hopefully the driver comes out ok with his injuries. Hopefully, your truck will come out ok too.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
#89 |
Hopefuly the driver is ok. it looked like he hit his head on the steering wheel prior to the air bag deploying. he cut his lip as well. I would have to gues he was traveling about 35 to 45 mph.
#90 |
I welded some 1"X3" tube to suport the back of the truck cab to make it easer to set it in place. I worked on the 69 quad cab for about 3 hours cutting out some sheet metal to fit the back of the truck cab. but the rear suport for the cab was getting cut off so I had to stop until I can get some material to suport it from the bottom. I would have gone to HD but I wont get a rental car until Monday. you can see in the pictures the area I will be cutting out so the floor of the truck and suburban will fit better. I will use the back cab body mounts to bolt the cab to the frame.
#91 |
That's a real bummer on the truck getting hit, hoping everything works out ok for you on that issue. Your making great progress on the project truck as well!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#92 |
You're going to need a D60 for the front of this beast...
#93 |
I have a Dana 60 for the front and 14 bolt for the back.
#94 |
Having to deal with my Dodge truck filing a claim with the insurance company and getting a rental car. I did not go to work today. After dinner I welded up some scrap tubing and built side suport so I can finish cutting out the back of the cab. I will try and finish up the left side later this week. I ordered a new floor patch panel to replace the one I cut short last Saturday.
#95 |
#96 |
loven this build. I want to do the same but my skills are no were close...
Please keep posting diy pix .thanks for sharing...
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
#97 |
Update?
#98 |
I had to work Saturday so work on the truck. Sunday I work on finishing up the suports for the back of the cab so I can fit the back of the truck cab on.
#99 |
After fitting the cab and getting it close I noticed that the tuck roof line is very low. A lot further off than I thought it would be. I'm thing about cut below the rear window at the line marked on the back of the cab and raise it up to fit the roof line better and fill in with a patch panel. It would be about 3 1/4" fill peice. I will see if there is anything else I can do for a better fit at the top.
#100 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Cut the top off of the suburban donor around the rain gutter area, and lower the roof to meet up with the truck roof. It will look funny if you keep the burb roof line. I have seen you can trim the burb roof to match up close with the truck cab roof line, and add a filler piece to mate it. Everyone does it different, but here's a good approach:
http://67-72chevytrucks.com/vboard/s...d.php?t=499490
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach):2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
