Old 10-28-2013, 08:56 PM   #351
duallyjams
duallyjams's Avatar
Re: DURG's Black 65 C10
Just finished getting caught up on your assume bad a** build.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-02-2013, 04:37 PM   #352
DURG
DURG's Avatar
Not much progress but I did get the widened rear wheel tubs sand blasted today.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 11-16-2013, 08:01 PM   #353
northern 85
northern 85's Avatar
Do i need to bring the camera down?? Did you ever look ito the gearvendors?
northern 85 is offline   Reply With Quote
Old 11-18-2013, 01:35 AM   #354
64chevtruck
Wow you make that look like fun. Nice work on tubbing the rear wells too, cant wait to see the bed finished thanks for sharing the pics,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 01-05-2014, 01:25 PM   #355
DURG
DURG's Avatar
It ain't much but at least I did something on the truck. I installed a Cherokee front door check with the two detent spots. Nice and smooth.
Fits: 1984 - 2001 Jeep Cherokee Front Left or Right Doors
Mopar Part #55235571AB
Old 01-05-2014, 02:19 PM   #356
likaroc13
Rollin' Old Skool
Thanks for posting that! I had forgotten that's something we need to do with mine. I remember a thread talking about the Cherokee door checks a while back, but I'm not sure if it had actual part #'s. Sometime during it's life before me, my driver's door suffered the typical crease associated with the door flinging open too far.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 01-05-2014, 07:56 PM   #357
Monte's62
Nice build DURG. I'm for sure following this one to the end. I may have missed it, but what did you end up doing on the transmission? You said you had a 400 and you were thinking about going through it to make sure it was up to snuff. Are you running the 400 or something else?
Monte's62 is offline   Reply With Quote
Old 01-05-2014, 08:18 PM   #358
DURG
DURG's Avatar
I had a turbo 350 lockup tranny not a 400. I bought a new non lockup turbo 350 from TCI.
Old 01-09-2014, 06:52 AM   #359
northern 85
Glad to see you back on the truck, how did the rear tubs come out?
Old 01-09-2014, 01:03 PM   #360
DURG
DURG's Avatar
Still at body work and paint. He is spraying the underside with rubberized undercoating.
Old 01-27-2014, 01:07 AM   #361
jlaird
jlaird's Avatar
Sweet build! Is the rear sway bar from speedway engineering?
jlaird is offline   Reply With Quote
Old 01-27-2014, 06:50 AM   #362
DURG
DURG's Avatar
Yes it is.
Old 01-27-2014, 06:54 AM   #363
DURG
DURG's Avatar
Got them back and they came out nice. Gloss black on top and spray on undercoating on the underside.
Installed the other Cherokee door check. Welded one small patch in left floorboard. I am just going to screw 1/4-20 button head bolts into the old mirror mounting holes where I took the large side view windows off. I need a second hand to hold a dolly inside to flatten out where the screws went in so a plastic washer can seal between the door and underside of the button head screw. I think I am going to use spanish oak on the bed wood. It's pretty dark.
Old 05-18-2014, 06:20 PM   #364
Chapstr's65
Chapstr's65's Avatar
So jealous
-Chapa
65 SWB step-side / 383 stroker / TH350 / 4:10 gears / static drop 4 1/2" front 5" rear.
Chapstr's65 is offline   Reply With Quote
Old 07-13-2014, 08:40 PM   #365
DURG
DURG's Avatar
Actually did something on the truck today. Sandblasted the radiator support, high hump, lower fender mounts and front frame to hinge mount braces. Also painted it all black except the high hump which I have some more grinding to do on the patch for the shifter hole. Nothing worth taking pictures of. Always fun sand blasting in July.
Old 07-13-2014, 08:47 PM   #366
lolife99
67-72 parts collector,…
lolife99's Avatar
Love this truck. Always look forward to updates.
Keith
Convert to disc brakes.
Old 12-04-2014, 08:09 PM   #367
DURG
DURG's Avatar
Welded in new kick panel patches. Got the new rear bumper gravel guards so the rear brackets and bumper can go on. I just bought an aftermarket stock type chrome bumper, as this truck had an accessory step and tow on it.
Old 12-04-2014, 10:50 PM   #368
ClassicHauler
ClassicHauler's Avatar
that's awesome, I gotta remember this for when I get to my truck. this looks a lot better than the little plastic or aluminum rivet that held mine on, until it broke at least.
ClassicHauler is offline   Reply With Quote
Old 12-31-2014, 12:16 AM   #369
DURG
DURG's Avatar
Cab going back on. Slow no-tech way of doing it. Jacks, blocking etc.
http://i224.photobucket.com/albums/d...pseed0c0b7.jpg
Old 12-31-2014, 05:06 PM   #370
DURG
DURG's Avatar
Old 12-31-2014, 05:07 PM   #371
DURG
DURG's Avatar
Old 12-31-2014, 05:26 PM   #372
duallyjams
duallyjams's Avatar
looking looking looking good
James
IG duallyjams
Old 12-31-2014, 05:29 PM   #373
northern 85
Love It!!!!!
Old 12-31-2014, 06:33 PM   #374
Dubnova
Very Nice!
Dubnova is offline   Reply With Quote
Old 01-01-2015, 12:32 AM   #375
likaroc13
Rollin' Old Skool
Love It!!!!!
Originally Posted by Dubnova View Post
Very Nice!
What they ^^^ said!
Phillip
My Build threads:
Pics:
Previous Rides:
