Old 12-11-2003, 02:57 PM   #1
86SILVERADO
86SILVERADO's Avatar
Engine Dilema!
Well,
The 307 in my dump burns a quart of oil every 100 miles. I have a $2500 350 in my half ton. I still have the original 305 which runs fine. I also have a 350 stripped down from a 72 which ran fine lowest cylinder was 130 and highest was 155. I tore it apart though for no good reason. So now figure if I was to use that motor I might as well re-build it which I could do for around 1200. I have the money right now but am probably going to buy a plow and don't really want to spend big bucks on another motor right now. I guess a list of what I see are my options would be best.
1. Swap out 350 for 305 in 1/2 ton and put 350 in Dump.
Pros:
a.brand new 350 don't really need it in 1/2 ton.
b.saves me the most money
Cons:
a. Will take me the most time which as always is at a premium.
b 305 really should be re-built even though it runs fine and burns little oil it still has 150k and leaks oil from every possible seal etc.
2. Re-build 350 from 72
Pros:
a. I have the motor and it would otherwise probably go to waste.
b. Don't have to waste the time pulling the 350 from the half ton AND re-installing the 305.
c. will have a 350 in both trucks although I am kinda missing the 20 mpg from the half ton.
Cons:
a. more money than I really should spend right now and going into the slow time of year for me.
3. Run the 307
Pros:
a. No $$$
b. No time
Cons:
a. oil consumption especially because I am wanting to plow with it this winter.
b. I am about to lose the throw out bearing and I know I gotta do it soon and am thinking well If I have to drop the tranny why not pull the motor at the same time and you know how that goes..LOL
4. Crate 350
Pros:
a. same $$ as re-building the 350 but with warranty (which actually means less to me than KNOWING that I will not have to go and pull the motor again in a month)
b. no time spent re-building the 350
Cons:
a. potential probs with crate motor.
b. 350 and 305 probably go to waste or rather I get like 400 for the both of them which I am not sure is worth it to me either.
So that was a mouthful. The only other thing I can think of is some kind of oil stabilizer or additive for the 307 which I have never done and would have to have some pretty convincing evidence to bother with.
Any suggestions...LOL
86 Silverado C10 back to 305 power!
67 C30 Dually Dump, with 350 transplant, Rockhauler
05 Duramax 3500
"If at first you don't succeed, try a bigger hammer"
Member of the 1-Ton club!
86SILVERADO is offline   Reply With Quote
Old 12-11-2003, 03:13 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
I would proably rebuild your 350 or buy a crate 350......305's suck in the power department.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-11-2003, 03:13 PM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Did you consider putting the 305 in the 67?
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 12-11-2003, 03:51 PM   #4
86SILVERADO
Hotrod 70
Now thats a damn good idea! Problem solved. WhooooHoooo. I don't think I would have thought of that. I don't mind putting the 305 in the dump because thats the work vehicle anyway. The only real problem with the 305 was that it was in a 1/2 ton truck with no gears an auto tranny and eight million miles of emmissions hose and accessories choking the heck out of it. I might even be able to up the compression by adding the heads from the 307. I will be very interested to see if I get any better gas mileage with the 305 as well. It's as good as done. I will let you all know how it goes. Thanks again,
Norris
I am going out to start it right now. LOL
05 Duramax 3500
