Old 12-11-2003, 03:10 PM   #26
lukecp
Formerly yellow72custom
lukecp's Avatar
Originally posted by 70c10
Lucas, that tach looks slick!. You have any pics or details how to cut out the back of the housing?
I don't have any details Jim, just kinda tore apart the insturment cluster and took a dremel with a cutoff wheel to it. I had to cut the lens where the tach is, the black metal piece behind that, and a small portion of the very back grey metal piece of the cluster. Take apart the cluster and you can figure it out pretty easily.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-11-2003, 03:17 PM   #27
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
That's exactly what I did, I would also recomend painting all of the green on the back portion of the cluster. It will make the rest of the guages brighter and the tach will not seem as bright.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 12-11-2003, 07:43 PM   #28
special70gmc
special70gmc's Avatar
i also did the autogage...............
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-11-2003, 08:16 PM   #29
Pilgrim
Can we see pics of the Coors model?
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
Old 12-11-2003, 10:29 PM   #30
miket
miket's Avatar
I used a Sunpro with programmable shift light integrated....I did cut the back of the cluster and mounted it.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 12-11-2003, 10:30 PM   #31
miket
miket's Avatar
Pic 2
Old 12-12-2003, 12:01 AM   #32
nitor
Too many projects
nitor's Avatar
Slammed67,
Doesn't that Camaro tach use a circuit board?
Jim
Jim
'55 Chevrolet Pickup
'56 Chevrolet Belair
'04 Chevrolet Astro
'95 Chevrolet Blazer
nitor is offline   Reply With Quote
Old 12-12-2003, 12:12 AM   #33
racedvl
racedvl's Avatar
Mine.
racedvl is offline   Reply With Quote
Old 12-12-2003, 12:41 AM   #34
ucmydust68
fuel
i have one of the summit ones that changes colors at the push of a button, i know kinda ricey but my lady got it for me and it fits perfectly flush and looks killer when it is lit up blue. let me see if i can get a pic
ucmydust68 is offline   Reply With Quote
Old 12-12-2003, 01:13 AM   #35
miket
miket's Avatar
Dude it's all good.
Old 12-12-2003, 01:28 AM   #36
dinnut
dinnut's Avatar
how do you do it with the circuit? do you run the wires underneath it?
i kinda like miket's
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-12-2003, 02:27 AM   #37
miket
miket's Avatar
Circuit panel is flexible....just ran the wires around it.
Old 12-12-2003, 08:56 AM   #38
jmanz69
Careful, they attack...
jmanz69's Avatar
The camaro tach doesn't need a circuit board, it has three lugs on the back, GND, 12V and tach input. Hook it up and go. There was a member who wrote up detailed instructions on how to put it in the dash too. Not any harder than putting in the others, and it looks more stock matches the factory gauges more. The others look good too, just can still tell it was not a factory part and looks very aftermarket, not that that's bad. All depends on what look you are going for.
jmanz69 is offline   Reply With Quote
