Old 10-31-2013, 09:05 AM   #1
Hart_Rod
Hart_Rod's Avatar
Question Question for the board - steering columns..
Is there a difference in splines or shaft diameter between the tilt and non-tilt columns on 67-72 trucks? What about the 73 and up trucks?
Hart_Rod is offline   Reply With Quote
Old 10-31-2013, 09:25 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Question for the board - steering columns..
If the shafts were different, the wheels would not interchange. I dont know about 73 up though.
Tom Vogel is offline   Reply With Quote
Old 10-31-2013, 12:11 PM   #3
Hart_Rod
Hart_Rod's Avatar
That's my experience also, just thought I would see if I was missing something.
Old 10-31-2013, 12:39 PM   #4
RenoKeene
Florida Edition
RenoKeene's Avatar
Hey Rob, In all my poking around I found no difference in shaft dia. Don't know about 73+, maybe the square guys could answer that.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
Old 10-31-2013, 12:59 PM   #5
Billett
Billett's Avatar
Same as the above guys said. Just did a swap myself from the non-tilt one piece shaft to a two piece tilt and they were the same.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 10-31-2013, 01:45 PM   #6
hugger6933
Do you mean where the steering wheel goes? that spline is the same from Gm through it whole line from the 60's until the mid 90's or until the use of driver side air bag. Even then as the wheel turned square but they are so ugly they don't count. That is why a lot of people use the wheel off of the chevy/GMC trucks from the late 80's early 90's on their 67-72's, and btw they look great on there. Also so does the Monte Carlo SS 2 spoke split wheel, my fav. Jim
hugger6933 is offline   Reply With Quote
Old 10-31-2013, 01:45 PM   #7
cdowns
cdowns's Avatar
no differance in splines either end
Old 11-02-2013, 10:12 AM   #8
Hart_Rod
Hart_Rod's Avatar
Thanks all for the info.
