Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 11-01-2013, 11:01 AM   #1
RidgeRaceCars
RidgeRaceCars's Avatar
"Help" T-221 problems won't engage in 2wheel drive
when i shift this thing in to to 2wheel drive,all the way forward on shifter input spins but output to rear doesn't....... Does the gear selector for 2wheel drive slide out one or two clicks???
RidgeRaceCars is offline   Reply With Quote
Old 11-03-2013, 11:19 AM   #2
RidgeRaceCars
Re: "Help" T-221 problems won't engage in 2wheel drive
Come on guys don't be shy!
Someone must know something!!!!!
Old 11-03-2013, 08:14 PM   #3
jbclassix
Junk Yartist
jbclassix's Avatar
Let me look at the one I have open and I will tell you
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 11-03-2013, 09:21 PM   #4
JPBrecheisen
See if this helps answer your question.
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
Old 11-04-2013, 10:04 AM   #5
RidgeRaceCars
Thanx!! i already have this diagram..... i figured it out aparently the selector shaft shift arm wasn't secured tightly and moved........ now it works fine.
Old 11-05-2013, 12:08 AM   #6
JPBrecheisen
Good deal. Glad you got it figured out.
