11-03-2013, 08:21 PM | #551 | ||
Re: Project Goldilocks, '66 C10 SWB BBW Build
Thanks Dino!!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
11-03-2013, 08:25 PM | #552 |
Cab is back on the frame and engine is dropped in. Will pick up some plate steel to notch the crossmember this week.
11-03-2013, 09:51 PM | #553 |
1 thing at a time is progress.
It should be illegal to do as nice as work as you do. Purely amazing!!
Alan
Philippians 2:14-16 |
11-04-2013, 09:36 AM | #554 |
Teaser def looks old school!
11-04-2013, 10:17 AM | #555 |
I'm just glad to be here!
That teaser pick is great! Should be one of the best looking LS motors out there!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
11-04-2013, 09:49 PM | #556 |
Thanks guys! I started cutting the notch out of the crossmember tonight but ran out of wheels for the big cut-off grinder. Will grab more tomorrow and get back at it.
11-05-2013, 09:17 PM | #557 |
Cut the crossmember tonight, and with my amazing blueprint drafting skills I drew up plans for the filler piece. Drawn to exact scale, of course... I'll have a fab shop bend a single piece of 3/16" steel instead of welding separate pieces together. Hopefully they can read my handwriting and get it done this week.
11-06-2013, 09:00 AM | #558 |
Detail is what I think of when I see all of your work, amazing stuff you do!
Jason |
11-06-2013, 09:30 AM | #559 |
Jaws will definitely drop when you pop the hood! Nice work
http://67-72chevytrucks.com/vboard/s...d.php?t=742865 66 SWB, C4 Dropmember timmytimm3 on IG "If you don't have time to do it right the first time, when will you?" -Dad |
11-06-2013, 06:54 PM | #560 |
The drawing is all the same color, no contrast
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
11-06-2013, 08:57 PM | #561 | |
Thanks! Hey now, atleast it's 3D!! And the dirty fingerprint marks adds a little color and contrast, that should count for something.
11-07-2013, 10:15 PM | #562 |
Picked up the filler plate from the fab shop today and welded it in tonight.
Fitting it in the notch, had to slightly open up the opening in a few places to get it to drop in. Cut lines scribed. Roughly trimmed to shape, edges still need work. After smoothing out the edges and matching their shape to the crossmember's shape. Then I removed the plate, beveled the edges for better penetration, welded it in, and started smoothing the welds. Still have to do the back half, ran out of time tonight. I've got a get together at church tomorrow night so it'll have to wait til Saturday.
11-07-2013, 11:40 PM | #563 |
Still Learning
Very clean work on the filler piece.
11-07-2013, 11:45 PM | #564 |
Very nice work there the extra effort is stunning..Vernski
11-07-2013, 11:51 PM | #565 |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
11-08-2013, 01:13 AM | #566 |
Thank you for the brief write up on how you went about matching up the filler piece to the cross member. Then go back and bevel out the edges for good penetration.
Never gets old seeing the quality of work you do along with reading on how to go about it correctly. |
11-08-2013, 08:34 AM | #567 |
x2... looks very good.
11-08-2013, 09:56 AM | #568 |
As usual your work is excellent
11-08-2013, 11:41 AM | #569 |
Very nice. Looks good.
11-08-2013, 04:05 PM | #570 |
Artist
The mad scientist at work.....
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
11-08-2013, 08:52 PM | #571 |
That came out great!
11-08-2013, 09:01 PM | #572 |
Just went through the entire build love it!!
11-08-2013, 10:19 PM | #573 | |
Thanks dudes!! Quote:
Thanks! It's nice to be back at work on it! Pretty stoked since Goodguys, I needed some motivation! Appreciate it!!
11-08-2013, 10:40 PM | #574 |
Slid the crossmember back in place and started to set the engine down... I might need more clearance in a couple spots. I measured the oil pan at it's widest point and added some for extra room... I didn't think about the block being wider.
There are a couple mounting bosses cast into the block that may need to be shaved if they're not used... or I'll have to rework the notch around them if I need to keep them. As it is I can't lower the engine all the way.
11-09-2013, 08:14 AM | #575 |
I think you should change your user name to the MACHINE as it is unbelievable of all the builds you have going at the same time and all of them are over the top with attention to every little detail.
And this is what John does in his spare time, I sent him a air cleaner lid to convert it to a dual snorkel.
