11-04-2013, 12:10 PM | #1 |
what tire combo you guys running on rally's?
I have 8" and 10" Rally wheels and was wondering what combo are you guys running on them? I would like to get some wide ones on the back like 295"s. I seen where some have 295 x 50 x 15 on the rear and in the front they have 275 x 60 x 15 and they say the tires are about the same height. To have 295"s in the back what's a good combo?
1974 C10 swb 350 1977 3/4 ton Silverado 454 1999 2 door 2wd Tahoe |
11-04-2013, 01:37 PM | #2 |
Re: what tire combo you guys running on rally's?
If you are fairly low I would suggest 295/50/15's on the rear and 245/60/15's on the front. That is what I was running.
5/7 drop. 5" BS on rear wheels
If you live in Oklahoma click this link |
11-04-2013, 03:08 PM | #3 |
I am planning on going with like a 4-5 drop, so in front I might be able to get 255 or bigger on there you think? That truck looks good you got there. So are those tires on that truck simiular in height?
11-04-2013, 03:19 PM | #4 |
They are close to the exact same. If you are going 4-5 drop I would reccomend a taller tire. Like a 275/60/15 on the rear and a 255 on the front.
11-04-2013, 03:27 PM | #5 |
yeah right now I already have 275 on rear and 245 on front. 15"s
11-04-2013, 04:55 PM | #6 |
Use this link to compare tire sizes.
http://www.sizemytires.com/calculato...FeuDQgodN1sACQ Last edited by geezer#99; 11-04-2013 at 05:07 PM. |
11-04-2013, 10:02 PM | #7 |
I found this link to be useful when tire shopping as well...especially with a staggered set-up or when changing to a larger wheel diameter. The "visual aid" was helpful.
http://www.tacomaworld.com/forum/tirecalc.php ...yes, I know that it's from a Toyota forum... |
11-04-2013, 10:32 PM | #8 |
I'm running 8's & 10's and I've got 235/70/15 BFG's on the front and 295/50/15 BFG's on the rear. The front tires are a little taller profile than the rear but I already had them on the truck and didn't want to buy new ones for now. With the front end sitting slightly lower than the rear the differences in the the tires isn't really noticeable because the tops of the tires are slighty tucked under the fenders.
11-04-2013, 10:58 PM | #9 |
I keep waiting to pull the trigger on some 10" Rallys. I am running 7 in front and 8 in back. 235/70/15....265/60/15
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
11-04-2013, 11:36 PM | #10 |
Diggin The SquareLife
mine 15x10 rear with 275/60 front is 15x8 with 255/60...but ima go to a 295/50 rear
11-05-2013, 01:43 AM | #11 |
Cruzzzn' Vet
15x10 with 295-50's and 15x8 with 245-60's
11-05-2013, 11:17 AM | #12 |
Nice trucks all you guys and thanks for replies. Thanks for the links geezer and surly. Sweet ride ymerej71. That's the truck i saw a while back that had the different sized wheels on it. Too cool.
11-08-2013, 10:15 PM | #13 |
Hey Baclay9 sweet ride what size of wheels are up running 15x10 and 15x8?
11-08-2013, 10:35 PM | #14 |
Yes and the 15x10's in the rear are 5" BS. Just FYI
11-08-2013, 11:02 PM | #15 |
Awesome thanks!
11-10-2013, 02:01 AM | #16 |
11-10-2013, 02:54 AM | #17 |
Stock aluminum with 235/75/15
11-10-2013, 02:57 AM | #18 |
I'm running 15x10's in the rear 15x8's in the front and I run BFGoodrich Radial T/A's 275/60 all the way around. I would've went with a 295 in the rear myself if I could find them in the BFGoodrich but I don't think they make 'em that wide.
11-10-2013, 03:46 AM | #19 |
Cruzzzn' Vet
11-10-2013, 09:45 AM | #20 |
11-10-2013, 04:09 PM | #21 |
Cruzzzn' Vet
Not sure but here's a pic
11-10-2013, 06:29 PM | #22 |
no drop obviously but my truck is sporting Hercules Terra Trac 30x9 50 R15 front and back
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab dd |
