11-05-2013, 05:31 PM | #1 |
Help plug 72 stock exhaust manifold holes
I wanna remove my smog pump on my 72. I don't need it an it'll give me more room to work on things. My question is what have other members used to plug the holes on the exhaust manifolds or any suggestions? Plus any advice on any vacuum lines I need to plug or anything else once I remove the smog stuff? I'm kinda new to all this an the more I do myself the more money it saves me to spend on other stuff for my truck. Thank you
11-05-2013, 06:12 PM | #2 |
Re: Help plug 72 stock exhaust manifold holes
I would hold onto all the smog stuff and not alter for someone who is going factory stock. If you have a 2wd truck, these manifolds are not tough to find.
I think the carb has one extra vac port. Other than a few brackets, carb, exhaust manifolds, pump and hoses, there is nothing else to take off. |
11-05-2013, 06:16 PM | #3 |
The holes in the exhaust manifold are NOT pipe plugs.....1/4''.....(although they will work in a pinch), you need to pickup some tubing plugs at your local parts store. I think they are 5/16 tubing.
11-05-2013, 08:49 PM | #4 |
Proprietor of Dale's Corner
Flare fitting plugs most REAL parts stores Napa etc...have them
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
11-16-2013, 12:25 AM | #5 |
Ever noticed some plugged with old spark plugs? MAN, what some people do!
Sam |
11-16-2013, 01:30 PM | #6 |
11-16-2013, 01:35 PM | #7 |
Thanks everyone for the help. I wanted to plug these holes with the proper fitting plugs cus after I install headers later on I may sell all the smog stuff including exhaust manifolds or thinking maybe I should keep it for later use INCASE the smog law changes here in California.
