Old 11-06-2013, 04:51 AM   #1
shipma3
question on foot pounds to tourq pan bolts on the 350?
what ft lbs should i tourqe the pan bolts on a th350??
shipma3 is offline   Reply With Quote
Old 11-06-2013, 10:20 AM   #2
manimal
manimal's Avatar
Re: question on foot pounds to tourq pan bolts on the 350?
run them up snug. I have never torqued oil pan bolts.
-Lance
2000 Chevy C2500, 5.7, 4L80e
1999 Suburban K2500, 7.4, 4L80e
1980 Camaro..son's car...PROJECT
manimal is offline   Reply With Quote
Old 11-06-2013, 11:08 AM   #3
77ChevySharkBite
77ChevySharkBite's Avatar
here's a link just for future reference on here it says it's 12ft lbs
http://boxwrench.net/specs/chevy_sb.htm
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 11-06-2013, 07:55 PM   #4
donut
donut's Avatar
I usually don't torque trans pan bolts either, snug works. Turbo 350, I believe is also 10-12 ft lbs.
'86 C-30 dually, 454/tbh400
'73 K-20 350/350/205 (sold )
I'm kinda like duct tape- no real purpose, but handy to have around.
donut is offline   Reply With Quote
Old 11-06-2013, 09:02 PM   #5
tinydb84
tinydb84's Avatar
Make sure your torque wrench is accurate that low. I learned the hard way and had to pull the engine twice
David
Instagram: myfabguy
Old 11-08-2013, 04:00 AM   #6
shipma3
i was figuring snug would work, that i will do and drive it and see if there is any leaks if so i will tighten it again thanks guys
Old 11-08-2013, 06:28 AM   #7
donut
donut's Avatar
While you got the pan dropped, make sure the rails are straight and the bolt holes aren't dimpled. Snug works, but the sealing surface must be good.
