![]() Join Date: Mar 2011
control arms difference
can anyone tell me if there is any difference between 68 and 71 control arms ball joints ? spindles ? thanks
jz
Grand Theft Auto https://67-72chevytrucks.com/vboard/...d.php?t=855961 Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
2WD Jimmy
![]() Join Date: Mar 2005
Re: control arms difference
None. My 72 control arms were dinged up. I got some 68 control arms from a buddy and used new ball joints and they went right in. Also used new everything else as well as my ECE drop spindles.
I was just researching the same question. looking at the LMC brochure the control arms are the same from 67-72 for a 1/2 T truck. there IS a difference for the part # of the ball joints. my guess is that whatever spindle you use the ball joints needs to match that year's spec. JUST MY GUESS, because I'm still researching it for my own project.
hopefully more knowledgeable folks can chime in too
1968 Chevy C10 swb fleetside ![]() 2005 Chevy Silverado crew cab (SS) 1977 Goldwing cafe racer 1977 Chevy nova (first car/ first love) ![]() |
#4 | |
thanks again jz
#5 | |
thanks jz
here are the control arms I have on my '71 swb. they are different from the ones I seen in the manual, no provision for a lower bump stop cushion. May be from a 67' model, but the ball joints fit and the 71' spindle bolted up just fine.
hope this helps Ben Smith |
2WD Jimmy
I should probably edit my first reply. No differences that Matter. Bump stops could be different, I think mine were shorter. However, ball joints and spindles Will fit fine.
![]() Join Date: Apr 2013
The geometry of them are the same.
But the difference is that the turn stop surface is different. The '71-'72 disk spindle knuckle has an angled surface that matches an angled surface on the lower a-frame (control arm) '70 and earlier have a different surface that the drum spindle knuckle stops against.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
#9 | |
thanks jz
#10 | |
thanks jz
2WD Jimmy
I removed mine to accomodate the adjustable ones that came with my ART bag setup.
I believe it will decrease your turning radius.
It's gonna be a while till I start this build I will report back when I do thanks to all for the input
Jz
