Lowered my 85 Today
Here is my 85 I lowered today.
2.5" Mcgauphys spindles 1 coil cut, Specialtyretail's Flip bracket and Shackles. 2" on pass and 1" on driver. Spindles hit the wheel weights so I used a Mr gasket 7/32" Spacer on the front. Notch and New Shocks hopefully this week, Not a Daily. Smaller Tires Soon. Wheels are Summit Racing 15x8 4.25 BS ![]() ![]() |
Re: Lowered my 85 Today
Looking good!!
Second Chance Program
Very good!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
looks sweet! good job!
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
Cruzzzn' Vet
Looks great, does not look bad with those tires either.
GoatLube Experss
![]() Join Date: Oct 2009
looks good .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
Clean truck
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" |
chevy runs deep
Looks good bro
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
BAD BOW-Silverado XST
Go to a 255/60R15 tire. Should fit just about right.
Looks good Ryan
appreciate it Wally
looks good!
1984 Chevrolet C10 |
Looks good low.
#15 |
Frequent Flyer
Looks good!
#16 |
So I replaced the front tires with 235/75s, Removed the spacers(Had to grind the spindle at the tire rods a tad and the LCA a little more). I installed shocks on it and need to lower the rear mount about 2". I swore I read someone used front shocks on the rear, So I picked up some and they are about maxed out at ride height. So when It compresses its ok but when it goes back up it locks out.
#17 |
Will I ever finish my 1986 stepper.. |
#18 |
I used a set of 79 Toyota truck rear shocks. The stock Toyo's are 19.5" extended and 12" compressed. The Chevy's are 22" and 14". They work great.
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 Last edited by Sodell; 11-24-2013 at 11:10 AM. |
#19 |
Do you reckon the angle of the shock with a flip kit makes it harder to compress on the stroke? I have thought about making a crossmember and mounting the shocks vertical behind the axle. Maybe even install air shocks that I have.
This 85 Chevy with the drop kit would look A hell of A lot better with you up in it. |
#20 |
Help me out. Im just about ready to do this to my short 78 C15. No notch yet? Maybe just shackles so far? Are u using ANY shocks at the moment? And..did u cut exactly one coil? Anyway, you're lookin good.
#21 |
I think you would still want them at the same angle. BTW truck looks nice, like the two tone white and red.
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
#22 |
![]() Join Date: Jun 2010
I kind of like it with the tires in the pic. That is one good lookin truck. Is that Apple red?
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
#23 |
The truck looks great. I have a 4.5/6 McGaughy's ready to install on my truck, but I've been waiting on doing it to rebuild some of the the front end. Did you install new upper & lower ball joints? Did you install new inner and outer bearings?
Azulita - 84 Chevy Scottsdale Longbed 305/350 |
#24 |
Love the look. Curious about the spindle clearance issue. Do you think this would still be a problem if you are using the stock rally wheels? I was planning on running the same spindle for a 2.5/4 drop. I have 30.5" tires right now though and was worried they would be an issue after lowering.
#25 | |
I actually trimmed the passenger coil more. I took out 1/2 coil and now its a hair off to the passenger side with a Tape measure, A lot harder to see by eye. I believe its different for each vehicle. I made marks on the spring before I cut it 12, 3, 6 and 9. I started off cutting a 1/4 coil and that wasnt enough so I did another 1/4 and left it.
