Old 11-10-2013, 07:41 PM   #1
ambros
Rear Wheel Size
I'm working on a 1965 Chevy c10 however have a later model rear end with a width of 64 inches mounting plate to mounting plate. I was Planning on putting 18x9.5 with a 275 tire and the rim has a 5 inch back space. When i was putting the car together i tried the front wheel and tire which is a 18x8 with 255 and a 4.5 inch back space on the rear end and with the fender on there was only about an inch of clearance from the end of the tire to the fender. I do not want to modify the fender so does anyone know if the 18x9.5 with a 275 tire would have any clearance or would i have to use the same size as the front?
ambros is offline   Reply With Quote
Old 11-10-2013, 07:53 PM   #2
G&R's57GMC
G&R's57GMC's Avatar
Re: Rear Wheel Size
If your using the stock rear suspension, bear in mind as it travels up & down the track bar will cause it to move the rear axle side to side up to a 1/4". Don't forget about the tire flexing during cornering.
As I recall the rear wheel opening is about the same size as the front. So a larger diameter tire in the rear would make it look stuffed.
What tire size are you running on the front ? 255/60R18 ?
Running the same size wheel and tire combo F & R allows you to rotate the tires.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 11-10-2013, 07:59 PM   #3
ambros
Re: Rear Wheel Size
255/55/r18 the rear end i think is from an 88-92 chevy c10 it was on the truck when i bought it
Old 11-10-2013, 08:11 PM   #4
G&R's57GMC
G&R's57GMC's Avatar
Re: Rear Wheel Size
If you want to have a big / little combo you could use 255/60Rx18 on the rear.
If your looking for the Fat rear tire the 275/50Rx18 on a 9" rim would be about as large as you could go BUT the backspace would be critical and you may have to roll the fender lip.
Looking again at your pic, the 275 may be to big for comfort. Don't forget the inner fender clearance also.
Glen & Jane's Rides
Old 11-10-2013, 08:18 PM   #5
ambros
Re: Rear Wheel Size
The Boss 338 next size up is 9.5 I think I will just have to go with same size as up front. The 8 inch have 4.5 backspace with a +2 offset 9.5 has a5 inch backspace with a -4 offset
Old 11-10-2013, 10:56 PM   #6
LVPhotos
LVPhotos's Avatar
Re: Rear Wheel Size
I run a 295/45/18 with no problems. I believe 4.5 backspace 18x9.5 rear. 1970 12 bolt.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-11-2013, 12:25 AM   #7
ambros
Re: Rear Wheel Size
Do you know the width of your rear axle mine is about 64 inch to the outside of the drums
Old 11-11-2013, 10:10 AM   #8
kieth
kieth's Avatar
Re: Rear Wheel Size
Another variable to keep in mind is that the rear axle is not centered on the wheel well opening. We are running a 275/70/r17 on the rear and we are going to have to move the rear axle back about 1.5" to keep the front inner lip from eating up the edge of the tire. The more you drop your truck in the rear the more chance you have of hitting that front lip due to the increase in diameter...........food for thought. Kieth
http://kieth.smugmug.com/Trucks/66-G...bvdJX&lb=1&s=A
kieth is offline   Reply With Quote
Old 11-11-2013, 10:13 AM   #9
64GMCHorsepower
Justified!
Re: Rear Wheel Size
I had this same problem when I dropped the rear of my truck. My 17's would hit the front lip.
Chad
1964 GMC Fleetside Shortbed....350/700R4 tranny
64GMCHorsepower is offline   Reply With Quote
Old 11-11-2013, 10:26 AM   #10
ambros
Re: Rear Wheel Size
Thanks for all the replies I think my best bet is to stay with the 18x8 and roll the fender
Old 02-11-2016, 09:54 AM   #11
kenwkirk
kenwkirk's Avatar
Re: Rear Wheel Size
you mentioned moving the rear axle back to accommodate for a larger tire ???? any simple answers for doing this ??? "ANYONE" ??? I am running a 4" drop ,,,, but want all the tire (18") tire that I can get ?? THANKS in advance
kenwkirk is offline   Reply With Quote
