Old 11-10-2013, 11:21 PM   #1
higgys72
sbc to bbc
im planning on going from a 350 to a 468 in my k10 i am wondering what all will need to be changed. will my motor mount locations stay the same? throttle cable? i know my exhaust will not line up and will need to be redonesome what. also have lots of questions about doing a tbi swap i have all parts for both swaps i think. i mean i have a running suburban with a 468 bbc with a tbi set up and a running non driving 72
For more consistent build updates fallow.
http://https://www.instagram.com/timhigginson90/
72 k10 build thread
http://67-72chevytrucks.com/vboard/s...62#post9002062
higgys72 is offline   Reply With Quote
Old 11-10-2013, 11:30 PM   #2
higgys72
Re: sbc to bbc
also what would i be better doing fuel injecting the motor i built and changing the cam in the bbc and droping it in my nova or giving the truck the bbc the way it is and giving the nova the sbc out of the truck. the bbc is dynoed at 353 hp 493 ft/lbs tq and the sbc i have no idea its a 30 over with 10.25:1 cr with vortech heads and mild cam. the sbc is original to the truck and ill more than likely have both cars forever. im looking for what ever option make the truck the most enjoyable nova gets the handme downs.
72 k10 build thread
Old 11-11-2013, 01:37 AM   #3
70c10stepside
Re: sbc to bbc
Some say something about the heater box. May have to take it out. But I dont know for sure. think only when using tall valve covers. Dad used to swap mine out from sbc to bbc all the time back in the day. Just the motor mount stands and exhaust were the issues. go for it. original? so? Throw it to the side for later if anything. Have some fun. Original will make it just like the rest lol
70c10stepside is offline   Reply With Quote
Old 11-11-2013, 10:12 AM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: sbc to bbc
Dont forget to do a forum search on this subject. Alot of people on here have done this!
Tom Vogel is offline   Reply With Quote
Old 12-18-2013, 09:02 PM   #5
2 Far Gone
Re: sbc to bbc
http://67-72chevytrucks.com/vboard/s...d.php?t=565381
http://67-72chevytrucks.com/vboard/s...=263273&page=4
http://67-72chevytrucks.com/vboard/s....php?p=5888239
http://67-72chevytrucks.com/vboard/s...d.php?t=225845
good info right there.......
Heater box wasn't an issue for me. I had to redrill and move everything back 2.5" back. PITA
2 Far Gone is offline   Reply With Quote
Old 12-18-2013, 09:18 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: sbc to bbc
Only 353 hp and 493 ftlbs out of a 468? Stock rebored engine?
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 12-18-2013, 09:22 PM   #7
jeh
jeh's Avatar
Re: sbc to bbc
I used motor mounts from POL (Performance Online) . I bolted them in the front set of holes. No valve cover or HEI problems. I don't have a lot of room for electric fans with a 4 row radiator, but I found a set that should work. I used Hedman full length big tube headers and had to do a little frame massaging, but they do hang pretty low for a dropped truck.
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 12-19-2013, 10:05 AM   #8
bigmac73
bigmac73's Avatar
Re: sbc to bbc
Gary
x2
sounds a little weak to me
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 01-05-2014, 12:53 AM   #9
higgys72
Re: sbc to bbc
Looked at the engine build sheet agaid the performance figures are projected not actual and it dosent say rwhp or crank hp. Here's the specs what do you guys think on performance.
Bored 60 over
C/r8.73:1
2.19 intake valve 1.88 exhaust
.501 lift intake and exhaust 214 @.050 duration 109 119 lobe center
Completely blueprinted and ballanced within 2 g
Edelbrock performer heads 110cc combustion chamber
1.7 rockers turbo city tbi system 14psi fuel press
Crane high out put coil and box
Cam 4deg advanced
72 k10 build thread
