#376 |
Wide n'Low
![]() Join Date: Jan 2007
Re: D52 Caliper Rear Disc Brake Brackets
Brackets arrived!
No I just need a couple of hours to get to them.. ![]() I will take pics as I go this week installing them and noting how things go. I'm looking forward to it.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
#377 |
Just read all of your threads on the brackets. That was a lot of good information that would have taken me way longer to find out if I had to research it all my self. To bad you repeat your self frequently because people don't take the time to read. I will be buying the 6 lug brackets from you soon, as long as I don't swap out my 12 bolt on my 69 C10. Thanks for all your hard work and great customer service Captainfab!!
#378 | |
60-66 Nut
Thanks for the compliments
![]() Let me know when you're ready to order. Quote:
#379 |
Does someone have the part number for the correct wilwood d-52 calipers. Looking at getting them from Summit since I have some credit with them. Thanks
#380 |
60-66 Nut
Do you need them for the front or rear? In black or red? Do you have 1" rotors or 1.25" rotors?
http://www.summitracing.com/search?S...0D52%20caliper
#381 |
Red ones for the rear with an astro disc. Thanks
#382 |
60-66 Nut
#383 |
GM Addicted
have any black brackets ready to ship?
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#384 |
60-66 Nut
Sorry but no I do not. I don't keep the powder coated ones in stock. In fact, right now I am out of one of the pieces for the D52's. I sold the last set yesterday. I do have more parts on order.
#385 |
GM Addicted
do i need to prepay for a set of powder coated ones? whats the wait time on other pieces?
#386 |
60-66 Nut
I should have my laser cutting by next Wednesday and hopefully have the powder coating by Friday. Whether you pay now or when the powder coating is done is up to you.
#387 |
![]() Join Date: Jan 2009
Would like to get a set of brackets for 12 bolt chevy
65 Chevy C10 Short Fleet BBW 6.0L/4l80E 68 Chevy C10 SWB 6.0L/4L80E 84 Chevy C10 SWB 5.3/4l60E QA1 Suspension |
#388 |
60-66 Nut
#389 |
Captain have you or anyone worked out the e-brake situation for these?
#390 |
PS I'll take a regular set for my 12-bolt regardless, but was curious if an ebrake solution had been worked out. Will paypal you here in a min.
#391 |
60-66 Nut
Right now all I have in stock is a set of powder coated D52 brackets. I will need to order some more laser cutting in the AM. I might be able to get that by the end of the week.
I do have some e-brake levers and cable brackets done and zinc plated, I just need to get some springs ordered.
#392 |
How much for those brackets, levers and springs? I'll send you the delta if that's stuff you can provide.
#393 |
60-66 Nut
I'll let you know once I find the correct springs.
#394 |
would like ordering info fore rear brackets bare steel on a 72 12 bolt with the d52 calipers and astro rotors. email is dkauffman05@yahoo.com
#395 |
im assuming if I buy thw wildwood calipers pt# 120-10938 for the rear and 120-10936 for the front I can just buy d52 brake pads local instead of buying the calipers that come with pads for $300+ ?
#396 |
Sorry Captainfab; I was just rereading this rear disc bracket info and I came across my 2 cents worth and I had said a 77 chevy truck diff. while I have a 64 chevy truck 12 bolt.It was rebuilt but I have to do a axle swap to a 5 lug so my tires will fit back on( it came with 6 lugs) so I have to order those first and by the postings I should be able to upgrade mt 12 bolt soon !!! What exactly do I need/LOL/I guess everything !!! Thanks
#397 | |
60-66 Nut
Yes you can just buy standard D52 brake pads from your local auto parts supplier and use them with the Wilwood D52 dual piston calipers.
I sent you an email ![]() Quote:
#398 | |
60-66 Nut
Since you have a '64 truck 12 bolt, you will also have to change the side spider gears along with the axles. Once you have the axles out, remove the backing plates. All of my rear disc conversion brackets except the Impala SS brackets, can be R&R'd without removing the axles.
#399 |
Sub'd for future use.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#400 |
Would like to get a set of brackets for a 12 bolt Chevy sent to Canada if possible
Thanks |
