Old 11-12-2013, 03:47 PM   #1
Jahloha
Jahloha's Avatar
Which trans? SPID & Build Sheet Each Use Different Codes
My truck is a 1970 C20 350
I am trying to plan out my project and trying to learn the pros and cons of my transmission, but only thing is that my SPID has code M49 which would be either for the TH350 or TH400...but my Build Sheet has code M38 which is only the TH350.
Is this normal?
I am building a dd and do not believe I have the skills to conduct a tranny swap, so I am wanting to pin point which trans I have, in order to read what all you have to say about the pros and cons of it. Or what I need to do in order to make whichever trans it is, a better dd (mpg).
Thanks for all your help with this.
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-12-2013, 04:12 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Which trans? SPID & Build Sheet Each Use Different Codes
What you say is correct about the RPO codes. TH400 would have been a M40 on the build sheet.
The TH350 is a fine transmission for all but the highest or torque/horsepower small block engines. It will also holdup to a very mild big block.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-12-2013, 04:15 PM   #3
Jahloha
Jahloha's Avatar
Digdav:
So I should go off the build sheet code? (I will also get under tonight to verify by using the pan bolt pattern).
Also, I have read all about the 700r4 being the trans for daily driving, but I dont feel quite ready for that sort of swap. So in the mean time, outside of rebuilding the trans, what other components things should I do, to make the th350 achieve its best mpg?
-JASON
Old 11-12-2013, 07:57 PM   #4
WIDESIDE72
WIDESIDE72's Avatar
Imo, buy a B&M shift improver kit, and when you have the pan off for the install, put in a new filter and fluid. Im not aware of much else you cna really do to one still in the truck.
WIDESIDE72 is offline   Reply With Quote
Old 11-12-2013, 08:01 PM   #5
Jahloha
Jahloha's Avatar
WestSide:
I plan on pulling the engine and trans next week...so options are open.
I made a contact with bud who's grandpa does trans rebuilds. The guy is nearly 70 and been working on old Chevys for forever. If I do end up going through him, what is a list of items he should do or I should ask him to do? To help this trans be the best it can for my daily driving.
-JASON
Old 11-12-2013, 09:27 PM   #6
WIDESIDE72
WIDESIDE72's Avatar
Originally Posted by Jahloha View Post
WestSide:
What type of driving do you plan for the truck? If a lot of highway driving is planned, now is the time to go with an overdrive. I have swapped a 700r4 into three 71/72 trucks. I also heled my brother install a 200 4r into a 72 in the early 90's. i really liked the dact that it dodnt have the low first fear like the 700r4. I also have a 200 4r in a 79 malibu. It lived behind a 500hp 383 til thecam went bad and ruined the engine. Its still in the car behind a milder 355. The cost of putting one in now is not that much higher than rebuilding your existing trans, other than the core needed. Your friends grand dad could surely help out there. Its really a straight forward swap. Youll need to slide the trans crossmember back and drill new holes. The driveshaft out of da mid 80's truck originally equipped with a 700r4 will bolt in. (Use one out of a swb if yours is a swb and likewise for lwb.) the tv cable bracket is available from several sources depending on what carb you run. the lower rpms will benefit you both with better mileage and extended engine life.
Old 11-12-2013, 11:13 PM   #7
Jahloha
Jahloha's Avatar
WestSide:
It will be a DD with a daily highway round trip of 20 miles, average about 320 miles every 15 days or so. The occasional 700 mile trip to SoCal and the occasional tow of a trailer.
Should I look for a rebuilt? Just looked online in my area and saw rebuilts for 600 and another from an early 90s burb for 75.
I am new to all this, but am trying to steepen my learning curve. So thanks for the help and input.
-JASON
Old 11-12-2013, 11:46 PM   #8
Lattimer
Lattimer's Avatar
swapping a trans is actually pretty easy. If you can take yours out and put it back, you can do the swap just as easy with some reading on this board.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 11-13-2013, 01:44 AM   #9
Jahloha
Jahloha's Avatar
FYI...I will also be running larger tires, probably 285/70/17 at the most. Will this tire size affect my choice of trans?
-JASON
Old 11-13-2013, 09:14 AM   #10
Keith Seymore
Keith Seymore's Avatar
Go by the build sheet; that's the document that drives the initial build. The SPID sheet reports what happened after the fact.
Also - you should be aware that there are "Merchandised Options" and "Non Merchandised Options".
Merchandised Options are what the consumer/dealer selects when he says "I want an automatic", or "I want a manual trans". That selects the "family" of options, so to speak.
The Non-Merchandised option selects the specific transmission within that family based on all the other design considerations (model/series, engine, rear axle, GVW, etc).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-13-2013, 11:24 AM   #11
Jahloha
Jahloha's Avatar
K
K:
Awesome insight on the merchandised and non-merchandised items. I never knew that, but it makes a lot of sense.
-JASON
