11-13-2013, 10:11 AM | #1 |
Fuel cell in bed
Hi guys, just got a fuel cell to put in the bed. It came with no sending unit. Im sure someone has done this so... its a 15 gal alum cell, which sending unit? I see them for 90 ohms, is this the one?? Also how do I figure out the proper one to get so it will read right inside for the float?? I bought the cell used so I need the help. Truck is still in paint so I have time to get all the goodies together. Thanks, Mike
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
11-13-2013, 01:04 PM | #2 |
Re: Fuel cell in bed
No one has moved the tank to the bed in a fuel cell? Hello.. is there anybody out there???
11-13-2013, 01:10 PM | #3 |
do not have specific answer but, search here for threads on gas tank/fuel gauge for info on stock gauge ohms. hopefully you will be running a cover for bed of truck - think about heat from Sun light on tank and fuel expanding.
11-13-2013, 01:12 PM | #4 |
I got a 12 gal fuel cell in the bed of mine but no sending unit..i filled it up and then ran it out of gas and wrote down my mileage..now my odometer is my gas gauge lol..but i think the 90 ohms one are for gm applications..Your have to take depth measurements of your fuel cell to get the right float height for a accurate gauge.
TRACK70 BUILD -> http://67-72chevytrucks.com/vboard/s...d.php?t=589761 King's Speed Shop |
11-13-2013, 04:00 PM | #5 |
Ahhhh cool, thats good info guys, Didnt think of heat. Cant be much worse than it running down the side of my paint.
11-13-2013, 04:58 PM | #6 |
I have a 15 gal marine cell under my toolbox. It has a sending unit and runs
to a gauge I installed in the empty slot by the steering column. I used an electric transfer switch, (heaven forbid--ford), and a toggle I installed on the dash where a choke cable used to be. The filler is inside the bed on the corner of the tank. I vented the tank with a hose that runs up to the rail. I have had no problems with it. It has been in the truck for about 10 years. EdB |
11-13-2013, 06:39 PM | #7 | |
Sam |
