Old 11-13-2013, 01:11 PM   #1
Jahloha
Jahloha's Avatar
Keep or Replace Eaton Rear End
I have a 1970 C20 with an Eaton rear end. I read everywhere on this site that the Eaton is a rock and if kept taken care of, will last forever.
But
I also read that parts for this rearend are very rare to find and purchase.
So being untaught, what parts are hard to find?
I hoping to do a disc swap on both the front and back...would this resolve the difficulty of finding these parts?
Thanks for the insight.
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-13-2013, 03:34 PM   #2
c20pickup
Re: Keep or Replace Eaton Rear End
the eaton is a tank, there are a few nice things about it, removable third member and also the rigidity of it. but that's about where the pros end. the hard parts to find for it, are basically everything, seals, bearings, brake parts, gear sets, hubs, lockers, etc. people have adapted the eaton to use 14 bolt backing plates and then Cadillac calipers to convert to discs brakes. also the option of lockers is also limited, seems as if you can find a factory "no-spin" lockers (very rare, and frankly overpriced for a used locker, ive looked into it) or you can use a locker out of a 14 bolt, but then you have to use 14 bolt axle shafts and shave them down 1/4 inch to accept the third member. in my opinion I would replace he axle with a dana 60 or a 14bolt, just for the fact that when it needs to be serviced, its not a hodge podge of parts all stuck together that needs to be custom made. and at what point, after changing all the internals and brake parts does a eaton remain an eaton? and at what point would it be easier to swap in something that already has discs and a locker. im open to questions, been doing a lot of researched on these axles lately. good luck!
c20pickup is offline   Reply With Quote
Old 11-13-2013, 08:30 PM   #3
Longhorn 70
Longhorn 70's Avatar
Bearings, brake parts, hubs, pinion supports and so on are kinda hard to find and pricey when you do. If it isn't a show truck, drive the Eaton until it breaks, if it ever does. THEN 14 bolt FFs are easy to find reasonable. Easy to change and adapt. Another big plus to the 14BFFs is there are more gear ratios available.
If it is a showgo, then get the prettiest and bolt it up.
My HO52 has over 450K miles on it and all I have really done is keep it lubed and seal leaks. I have POUNDED that thing with torque and carried, not many, heavy loads from time to time. It has also been when I was young and dumb, used at high speeds. It isn't pretty but it works.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 11-13-2013, 09:16 PM   #4
Jahloha
Jahloha's Avatar
Longhorn:
Good to chat with you again. Quick question, if I said this was going to be a daily driver where MPG matters to me, would that change your mind at all regarding the swap?
I really am concerned about parts accessibility 5, 10, 15 years down the road; but durability is always a concern. So wheres the line for you to make the swap or not?
Thanks again.
PS...I also consider this an option for the rear disc swap that I have asked you about before.
-JASON
Old 11-13-2013, 10:28 PM   #5
swamp rat
swamp rat's Avatar
You can get all the bearings, seals and even the felt pinion seal for the diff thru Randys Ring and Pinion in Seattle, That includes the big pinion bearing but it is expensive.
Wheel hub bearings and seals can be bought at the auto parts store, the only replacements are tapered roller bearings instead if the Barrel bearings.
Brake parts can be found but don't all come easy, the shoes can be relined if necessary, i think even the drums can still be found.
You can use a conversion bracket for a 14 bolt disk conversion on the Eaton, some places market one for the Eaton too.
Front rotors and calipers from a 72 4X4 will work on the rear, so it should be the same on a C20, just know there are light duty and heavy duty rotors and calipers, you do want the heavy duty stuff, 1" thick rotors are light duty, 1 1/4" thick rotors are heavy duty.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-14-2013, 08:54 AM   #6
Do what those of us who have driven older vehicles daily have always done...get the parts now while you can and have them ready for the day you might possibly need them. If not,years down the road you'll have parts no one else can get to sell when you move on. Or,you could buy the parts,install them,whether they need it or not,and be good to go. Parts may be higher on these,but they aren't cheap on a 14-bolt and,unless someone gives you one already altered to go under a 67-72,you're looking at some expense there. If you do discs,your only concern is wheel bearings. Even if those go extinct from parts stores,I've found you can usually find bearing by dimension from a bearing distributor. Also,14-bolt brakes can be fitted up to an HO52 Corporate rear.
Or,you could just run it,maintain it,and not worry about the rare chance a problem will occur. These rears are under GM Trucks dating back into the '40s
Old 11-14-2013, 10:36 AM   #7
Jahloha
Jahloha's Avatar
Special K:
I appreciate your input a lot. I like the idea of buying the parts now and maintaining the rear end a lot. Some quick question for you:
-What is your current set up and how is your mpg? (engine, trans, rear)
This will be my dd and am looking for 15+ mpg when all is said and done.
-JASON
Old 11-14-2013, 11:05 AM   #8
Longhorn 70
The rear end shouldn't change that much regarding MPG. It is the gearing that would make a difference. You CAN get more gear ratios with the 14BFF. IF the gearing you have now works for you keep driving it. If you need to get the rear changed in the future, the 14BFFs will still be out there.
As I stated before, I have 450K+ miles on mine. No noise, no clunks, no whine or real leaks. I'd trust mine for a daily driver. There are a BUNCH of Eatons on the road.
Old 11-14-2013, 11:15 AM   #9
No matter what rear you have,it's the gear ratio that effects fuel mileage. My current truck is a K2500 with Dana60 4.10 posi and it gets 12.5 mpg with 350/TH350 and I haven't touched the carb in 10 years. My plans are to swap-in an HO52/No-Spin. For even better mileage I suggest O/D. I could do things under the hood to achieve better mileage,but this truck isn't for daily use. Plans are for a Dana60 front axle,37" tall tires,383/TH400.I'm going for tough and strong on this one. I actually gave the 4L80E/NP241 RH drop w/stand-alone ECM to a friend who has done me a lot of favors. I'm happy with 60-65 on the hiway and all O/D does for most people is allow them to drive faster and use the same amount of full as if they drove a more reasonable speed. When I drive my '92 with 4.10s and O/D @65mph I get 2-3 mpg better than doing 70-75.
Old 11-14-2013, 11:22 AM   #10
Jahloha
Jahloha's Avatar
Great insight. I have read how to verify my gearing, but need to do that. Plan on doing that this weekend after the bed is pulled. Did you ever end up doing the rear disc brakes? I saw you following a thread on the BlackBird disc kits...
Makes a lot of sense. I do tend to drive closer to 70 then 60, so the O/D seems to make sense. I also use this daily and sometimes make 80 mile round trips, but usually 20-30 miles.
Also, I have read threads on how certain tires heights should be used with certain gears. Are you familiar with any posts that dive into that topic?
-JASON
Old 11-14-2013, 11:48 AM   #11
Longhorn 70
I haven't yet. I have to get approval from the CFO. She is a tough one. MAYBE I should put it on my Christmas wish list.
Old 11-14-2013, 12:02 PM   #12
Jahloha
Jahloha's Avatar
Haha, I totally understand. I am compiling a mass budget for this build, its always fun to run numbers, but sad to realize the actual costs.
I am trying to find the thread you started, or at least I think you did, on your front disc install. Do you have that link available? Or am I mistaken.
-JASON
Old 11-14-2013, 12:28 PM   #13
Longhorn 70
Originally Posted by Jahloha View Post
...I am trying to find the thread you started, or at least I think you did, on your front disc install. Do you have that link available? Or am I mistaken.
Is this the thread you mean? It's the only one I can think of. It is more the outline of what I ran into while installing the front disc kit.
Old 11-14-2013, 12:32 PM   #14
Jahloha
Jahloha's Avatar
Bingo. Thanks.
-JASON
Old 11-14-2013, 09:41 PM   #16
c20pickup
ill look forward to a thread when it is approved!
Old 11-15-2013, 12:18 AM   #17
Jahloha
Jahloha's Avatar
Originally Posted by swamp rat View Post
If you guys are interested here's all the Threads i saved with pertinent info on the Eaton, this includes both drum brakes as well as some disk conversions info..
http://67-72chevytrucks.com/vboard/s...d.php?t=595571
http://67-72chevytrucks.com/vboard/s...d.php?t=200268
http://67-72chevytrucks.com/vboard/s...d.php?t=590959
http://67-72chevytrucks.com/vboard/s...d.php?t=593259
http://67-72chevytrucks.com/vboard/s...d.php?t=540983
http://67-72chevytrucks.com/vboard/s...d.php?t=475710
http://67-72chevytrucks.com/vboard/s...d.php?t=401974
http://67-72chevytrucks.com/vboard/s...d.php?t=183452
http://67-72chevytrucks.com/vboard/s...d.php?t=408600
http://67-72chevytrucks.com/vboard/s...d.php?t=401745
http://67-72chevytrucks.com/vboard/s...d.php?t=399201
http://67-72chevytrucks.com/vboard/s...d.php?t=391609
http://67-72chevytrucks.com/vboard/s...d.php?t=172827
Holy cow! Awesome bro. Looks like I got some midnight reading to do. Im pumped
-JASON
Old 11-15-2013, 09:01 AM   #18
I've driven from Maryland to the Grand Canyon and back on a '71 Custom Camper/20 with camper @75 mph out & back with 4.10 rear and never missed a lick. These trucks can roll all day with the rest w/o overdrive. But,if fuel consumption is a concern,slower is better...with or w/o it.
Old 11-15-2013, 01:41 PM   #19
Jahloha
Jahloha's Avatar
Yeah Special K I totally know what you mean. So would throwing in a 700r4 been change anything? Or does it all come down to the gear ration I'm running in back (I've yet to figure out what my ratio is)?
I respect your insight, so thanks for sharing your thoughts.
-JASON
Old 11-15-2013, 02:45 PM   #20
Longhorn 70
Jaloha, first let me say and I think I speak for others on the board, we appreciate the respect you give to other's opinions.
Second, a 700R4 will make the engine turn fewer RPM for a given speed over 45MPH.
Third, 700R4s have a lower first gear that gets you out of the hole with less engine effort.
Fourth, the 700R4 in my beast allows me to get better mileage on sustained cruises. I choose whether or not to get that better mileage by how hard I push the pedal.
Now the bad news: Price, Strength as compared to TH400s, some don't like the low first gear, modifications needed, are factors that need to be considered.
Personally I like the lower first gear with the low geared rear end in my truck and the overdrive helps too. It cost me $1200 in 97 to get a 700R4 built and installed and I did the installing. Was it worth the extra 4 MPG hiway?? Over the 6 years of savings, yes especially because I was replacing a broken TH400. If the 400 weren't broken.....I dunno'.
Old 11-15-2013, 05:03 PM   #21
OldCreek
OldCreek's Avatar
If it ain't broke, don't fix it.
Most all wear parts can still be had from my experience.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 11-15-2013, 05:24 PM   #22
Jahloha
Jahloha's Avatar
Longhorn:
This is a great way to describe and compare these transmissions. I almost exclusively do highway driving, at least I am over 45 all the time haha. So that does attract me. I also look at the fact that if I am going to rebuild the trans anyways, I might as well drop a couple hundred more and get the 700r4 in. I am in with you, if this is my DD, and I am putting 10-15k miles a year on it, better make the swap now.
-JASON
