Old 11-13-2013, 11:32 PM   #1
ChevykidHB
ChevykidHB's Avatar
Rochester carb swap/ replacement
looking for a replacement for my ailing carter quadrajet. will any quadrajet bolt on to my stock intake or will i need to change stuff around? or are there better options edelbrock or holley that will suit my needs? needs being daily driver with occasional towing.
thanks in advance!
also where are the casting numbers on these? might rebuild it after i swap it
1970 c20 cst 350/400 14bolt rear
ChevykidHB is offline   Reply With Quote
Old 11-14-2013, 12:21 AM   #2
Classic-Steele
Classic-Steele's Avatar
Re: Rochester carb swap/ replacement
I'd just rebuild the quadrajet you have. I just finished and its not that hard asst all. The model number is stamped vertically on the drivers side towards the back.
Classic-Steele is offline   Reply With Quote
Old 11-14-2013, 01:44 AM   #3
ChevykidHB
ChevykidHB's Avatar
thats what i was thinking. but im afraid i may have a warped air horn in the carb (its making a weird whistle noise) so im wondering if id be better off just changing it out
Old 11-15-2013, 01:18 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: Rochester carb swap/ replacement
Since u said "its making a weird whistle noise", I'd be looking for a vacuum leak--not around air horn, but usual places like base-mounting gasket, vac-hoses, pwr-brake hose, manifold "vacuum trees", intake surfaces. Stopping such a vac leak may cure your "ailing carb" symptoms.
If air horn is warped you'd more than likely find a fuel leak--but not a vac leak. Ever tried to run an engine, in the shop, with air horn completely removed from top of a quadrajet? May reveal a lot of surprises.
Sam
luvbowties is offline   Reply With Quote
Old 11-15-2013, 02:41 PM   #5
davepl
davepl's Avatar
I'd send it to Carb Connection in Kirkland WA or some other expert QJet rebuilder. I've also had moderate luck with Stage II Qjets from "Jet", but have also heard that the rebuilders get a lot of them fresh off the shelf to be redone.
Anyway, QJets are such a flexible carb that pretty much anything will run with any QJet, but to run well or properly it's going to need a knowledgeable tuneup whether its new or rebuilt. Besides, even if rebuilt perfectly to factory specs or replaced with an NOS perfect one, fuel is different than when they built the calibration into them 40 years ago.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
