11-14-2013, 08:17 PM | #1 |
Belt Help!!!!!!
I have an alternator belt that won't stop squealing. I changed belts and no difference, changed alternators and no difference and I even sanded the pulley grooves with a medium grit and no difference. I even aligned them the best I could and still yet again no difference. It only squeals at idle when I rev it hard or hit the gas hard on driving. Any input would be appreciated.
11-14-2013, 09:46 PM | #2 |
Re: Belt Help!!!!!!
Find a belt that fits's deeper in the pulley. The one on the water pump looks to be sitting a bit high.
11-14-2013, 10:44 PM | #3 |
Re: Belt Help!!!!!!
Both belts are almost flush with pulley itself and I don't have any problems with the belt that that goes from pump to crankshaft to power steering. Its the alternator for sure.
11-15-2013, 02:40 AM | #4 |
20' Daredevil (Ret)
Re: Belt Help!!!!!!
Have you made sure the vee-angle of the belt exactly matches the vee-angle of the pulley grooves? My only other thought is that in spite of your efforts, the pulleys might not be in perfect alignment. Can't tell by the pic, sorry.
Have you tried rubbing a bar of soap against the belt with the engine idling? It won't fix the problem but will often stop the squealing for a short time. Just one more way of proving that's the problem belt. Usual disclaimer about keeping clothing and fingers away from moving fans, belts, & pulleys....
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-15-2013, 03:26 AM | #5 | |
Re: Belt Help!!!!!!
11-15-2013, 09:39 AM | #6 |
I am a Referee of life.
Re: Belt Help!!!!!!
When you look at v belts,check that the angles are the same in this area \V/ .There are differences in belts and the actual grip from a V belt comes from the area between the slash and the v.If those angles don't match,you will have very little grip area and squealing will occur.Belts should not have to be extremely tight to grip but should be snug.Debris in the bottom of the pulley,not allowing the v area to seat down into the groove well will also cause this.I see the belt is notched on the back side which is pretty common with industrial belts which have tons of variations.Belts should also be either flush or just under the top of the pulley foor full contact thru the v area. Just some inights I have learned over the years.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
11-15-2013, 12:41 PM | #7 | |
Re: Belt Help!!!!!!
Sam |
11-15-2013, 12:45 PM | #8 | |
20' Daredevil (Ret)
Re: Belt Help!!!!!!
Thanks for explaining it much better than I did!
11-15-2013, 12:50 PM | #9 | |
Re: Belt Help!!!!!!
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
11-15-2013, 05:44 PM | #10 | |
Re: Belt Help!!!!!!
11-16-2013, 12:43 PM | #11 |
Roto Reuter thats the name...
Re: Belt Help!!!!!!
I have a serpentine set up, but had similar problem with belt squeal. Thought I had a good belt with Dayton. Chased the problem for a while. Finally someone told me to ditch the Dayton and go with a NAPA gold belt. Problem solved. I know it's not the same as yours, but just a thought. Good luck.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
11-16-2013, 04:51 PM | #12 | |
Re: Belt Help!!!!!!
11-16-2013, 05:30 PM | #13 | ||
20' Daredevil (Ret)
Re: Belt Help!!!!!!
How does the belt fit the waterpump pulley? If it's good, you might have the right belt, but need a different pulley on the alternator.
11-16-2013, 06:11 PM | #14 |
Re: Belt Help!!!!!!
Whats The Number On The Belt ???
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
11-16-2013, 06:53 PM | #15 | |
Re: Belt Help!!!!!!
11-16-2013, 06:54 PM | #16 |
Re: Belt Help!!!!!!
11-16-2013, 09:01 PM | #17 |
Re: Belt Help!!!!!!
Have you tried belt dressing?
You might need to go to a double belt pulley set up. http://prestone.com/enca/node/437 |
11-16-2013, 11:07 PM | #18 |
Re: Belt Help!!!!!!
You say it is the alternator belt slipping for sure. How do you know that? Is the alternator belt slipping on the alternator or on the water pump?
I'm not saying it's not, I just would like to know how you are making that determination. The two grooves on the water pump pulley appear to be different diameters. Are the two grooves on the crank pulley also different diameters? If the two grooves on the crank pulley are the same diameters, both belts will be traveling at the same speed. That means that at least one belt will be slipping on the water pump pulley at all times. One belt is on the tension side of the drive pulley, the other belt is on the take-up side of the drive pulley. That can have an effect on what you're hearing and when. There are several things that may be in play here. Pulley diameter matchup and degrees of contact on the circumference of the pulleys. Better pictures of all the pulley positions would be helpful.
'67 GMC 2500, 292, 4spd, AC |
11-16-2013, 11:11 PM | #19 |
Re: Belt Help!!!!!!
How tight did you put it on? You should pull it tight, then slightly let up so there is a small amount of sag on the either the top or bottom, then tighten your bolt.
project: "my happy mess" |
11-17-2013, 12:50 AM | #20 |
20' Daredevil (Ret)
Re: Belt Help!!!!!!
I tried belt dressing and all it did was made a sticky mess. Never again. I emptied the can killing carpenter bees, so it wasn't a total loss.
11-17-2013, 03:47 AM | #21 |
Re: Belt Help!!!!!!
Take the belts off and fire up the truck and see if the squeal stops, then put 1 belt on and try again, then take that belt off and install the other belt..
One time i had a belt squeal that was driving me crazy trying to figure it out, it turned out that the manifold vacuum port for the tranny was left unplugged and the tranny vacuum tube was hooked to the carb, it was a vacuum leak that would whistle when the engine was revved, something to consider?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-17-2013, 04:28 PM | #22 | ||
Re: Belt Help!!!!!!
11-17-2013, 04:36 PM | #23 | |
Re: Belt Help!!!!!!
11-17-2013, 04:51 PM | #24 | |
Re: Belt Help!!!!!!
11-17-2013, 05:03 PM | #25 |
Re: Belt Help!!!!!!
Loosen the belt as much as you can to see if/when it stops squealing, then gradually tighten up to where it starts squealing again. I'm guessing you know it isn't a bearing sound.
