Old 11-16-2013, 04:05 PM   #1
true74enduro
I think the shop is took my truck into messed it up
I have an 85 k10 I think the shop I took my truck into installed my new steering stabilizer wrong. Can someone post a picture on how a single stabilizer looks
true74enduro is offline   Reply With Quote
Old 11-17-2013, 11:30 AM   #2
kalbert
Re: I think the shop is took my truck into messed it up
There isn't really a wrong way, it will only go on one way. It mounts to the frame on one end and the drag link in the other end. What's leading you to think yours is wrong?
kalbert is offline   Reply With Quote
Old 11-17-2013, 02:43 PM   #3
true74enduro
The attaching end are switched the end that mounts to the frame is attaching to the drag link is that ok?
Old 11-17-2013, 04:01 PM   #4
russgt
russgt's Avatar
Post a pic
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 11-17-2013, 09:11 PM   #5
NASTY-LSX
Originally Posted by russgt View Post
Post a pic
I agree, let us see for ourselves
NASTY-LSX is offline   Reply With Quote
Old 11-17-2013, 10:13 PM   #6
dieseldawg142
dieseldawg142's Avatar
yeah, there really is no wrong way, if using the stock brackets. if not using the stock brackets, just make sure you have enough stroke to cycle the wheels both ways.
an old bds stabilizer. crappy pic, had to jack up the brightness to see it
dieseldawg142 is offline   Reply With Quote
Old 11-27-2013, 09:06 PM   #7
true74enduro
Here's mine maybe they ordered one with not enough stroke it will feel like I'm on my steering stops if I crank it to the left
Old 12-01-2013, 08:39 PM   #8
true74enduro
Does it look like they did it right
Old 12-01-2013, 08:45 PM   #9
russgt
russgt's Avatar
Are you saying that you cant turn to the left?
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 12-01-2013, 09:01 PM   #10
LONGHAIR
What? Frame and drag link?
No, it goes between the axle housing in the tie-rod. An '85 should have a bracket welded to the housing near the center, close to where the tube goes into the casting. The other end is a tapered hole in the tie-rod itself, closer to the driver's side.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-01-2013, 09:18 PM   #11
true74enduro
Yes I can turn right fine but when I do it make a slight pop noise so it seems to me that maybe the stabilizer doesn't have the right amount of stroke. Or I was thinking the stabilizer got installed backwards or so it extends the other way
Old 12-01-2013, 11:31 PM   #12
Oldriginal86
Remove end from tie rod. Turn fully left. Pull out rod from stabilizer to see if it will reach. If it doesn't then take the truck back.
Oldriginal86 is offline   Reply With Quote
Old 12-01-2013, 11:40 PM   #13
true74enduro
Ok that makes seance will check thanks
Old 12-02-2013, 07:19 PM   #14
LONGHAIR
Just looking at the pic provided, I would bet that something is wrong. It seems, from this angle that this is put together with a single bolt all the way through the shock and the tie-rod? If so, it is likely that nothing was done to accommodate the tapered hole. It is supposed to be installed with a stud that fits the taper, which also spaces the shock away from the tie-rod by 1/2"or so.
This improper bolt may be causing some of your bind.
Old 12-02-2013, 08:30 PM   #15
true74enduro
That could be the case. When I pulled it off today I notice that the bolt your stating is a regular bolt with a machined tappered sleeve slipped over it
Old 12-02-2013, 09:31 PM   #16
meatwagon83
meatwagon83's Avatar
learn to work on your own junk, it makes your truck much more special to you! its cheaper and you will only have yourself to blame when things go wrong, that being said i think it has the wrong damper on it
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 12-02-2013, 09:33 PM   #17
true74enduro
That's what I'm thinking I usually always work on mine I just didn't have the time and it needed to be done. Thanks guys for the help I'll have to check my stabilizer tomorrow
