Old 11-18-2013, 07:09 PM   #1
Billett
Billett's Avatar
Remote Starter
Cleaning out the garage the other day when I stumbled across a box of stuff I had for my old s10. In there was the unopened remote starter I had bought to install, but never got around to. Anyone on here run a remote starter on one of their swaps? I know many of them came from the factory with remotes, but I don't know if a swap is any different.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 11-18-2013, 09:41 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Remote Starter
Most of the aftermarket ones I've seen were total trash until you spent $250+ for a GOOD one, professionally installed. Its more wiring than the whole LS swap itself.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-18-2013, 11:29 PM   #3
ls1nova71
ls1nova71's Avatar
Re: Remote Starter
I have DEI remote start/alarms on most of my swaps. The remote start part isn't really all that involved, but the whole package does add up to a lot of wiring when you start adding in starter kill, keyless entry, illuminated entry ect. As Br3w said, if it's a cheap one from like Wal-Mart or something, then you would probably be better off with out it. I bought one of those $50 jobs to put on a winter beater and it never did work right. I took it back and got a Python (DEI) and it worked great up until the day I junked the car, then I pulled it off and now it's on my green beater '71 swb.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-18-2013, 11:57 PM   #4
awhite4557
awhite4557's Avatar
Re: Remote Starter
I have a VIPER alarm with remote start on my 71 with 5.3 fuel injection. It works great but wasn't cheap.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 11-19-2013, 02:26 PM   #5
Billett
Billett's Avatar
Re: Remote Starter
My unit is pretty decent, just wondered who had done it already and if any sort of bypass like Passlock was needed. I know my s10 needed one, so I wasn't sure about this.
Will
2024 Toyota Sienna
Old 11-19-2013, 06:40 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Remote Starter
I'd think if VATS was deleted for your swap, there would be nothing else that would really interfere. I thought the PassLock thing was one of GM's aborted concepts. All it ever did was cause guys with Fbodies to complain...
Old 11-19-2013, 07:00 PM   #7
Billett
Billett's Avatar
Re: Remote Starter
I thought that was the case too, just wasn't sure. Don't know much about passlock, just that the s10 needed a ~$30 module to bypass it in order to install the remote start with the factory 4.3L. My understanding is that Passlock is/was tied into the VATS like you said, and since it's disabled in a swap PCM it doesn't need to be bypassed. Since my s10 was still factory I needed to get the module, or get a tune and bypass it like I did here. Thanks for the heads up. I'll post up later if and when I do this.
Will
2024 Toyota Sienna
Old 11-19-2013, 07:36 PM   #8
Smurfeh
Re: Remote Starter
I have command start on one of the blazers.. actually the one I'm doing a swap on right now.. The PO was the guy that put it in. Looks like he just spliced into the connections that he needed., and thats it. The antenna has been cut so its useless now (impedance matched), also doesn't help there was no keyFob. I've looked up the Part number and its apparently discontinued. I just left it in. I haven't got my harness back from Current performance yet so I have no idea if it'll interfere. I've never used current performance before any one have comments or reviews? sorry to get side tracked.
Smurfeh is offline   Reply With Quote
Old 11-19-2013, 09:21 PM   #9
ls1nova71
ls1nova71's Avatar
Re: Remote Starter
VATS is Passlock, that's what GM calls their antitheft system. Since you have the VATS tuned out, you don't need anything else. The $30 bypass you needed for the S10 sent a signal to the BCM to trick the PCM into thinking the correct resistance key was in the ignition.
Old 11-19-2013, 10:02 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Remote Starter
but what actually happened to the thing they called "Passlock" that would flash on the dash on the 90's GM stuff. Like even before VATS.
Old 11-20-2013, 12:53 PM   #11
Billett
Billett's Avatar
Re: Remote Starter
I actually used CPW for my harness. It turned out awesome and I'm very happy with it.
Will
2024 Toyota Sienna
