#26 |
Re: 1960 1 ton pics
Well all I have done is what you see. That coil is what I had laying around. As soon as i figure out the electrical issue I bet it will fire right off. Coil has enough juice to burn the hair of a spiders keister.
I had to "convince" the coil bracket to accept a skinny smoother coil. I homemade a L bracket and welded it on...that sucker is not going anywhere.
No trees were killed to send this note but a large number of electrons were terribly inconvenienced. AKA. RABIDJOE... if you have to ask you prob don't want to know. Ive had my shots *dont worry* 1960 235 4SPD C30 |
#27 |
![]() Join Date: Mar 2013
Re: 1960 1 ton pics
Here is a picture of my Junior West Coast Chrome mirrors.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#28 |
Re: 1960 1 ton pics
The west coast mirrors will look good on it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#29 |
Re: 1960 1 ton pics
Those are some decent looking mirrors. I have no idea what i will use since mine are gone. lol
Do any of you know if these wheels will fit my 60? http://lawton.craigslist.org/pts/4158017891.html
#30 |
Re: 1960 1 ton pics
if I remember correctly the new wheels will not fit your truck. The lug pattern is the same but the center whole is too small for the older trucks. You can get 73-87 bud wheels from a newer dully if you are wanting to keep it dual wheel. I have a set for my
'65. |
#31 |
Re: 1960 1 ton pics
I think they work; I've seen quite a few older trucks with them (I almost put some on mine). Lug nuts and studs might need to be changed; IIRC you can get a 9/16" lug nut that works with the caps, I'm not sure about 1/2" stuff. They are called "PYO" wheels, BTW. I think the 67-72 guys have a couple threads, I'll try to dig one up.
#32 |
Re: 1960 1 ton pics
#33 |
Re: 1960 1 ton pics
OH SNAP it looks like they will fit! I have single wheels I lucked out don't have a dully. Guess i better jump on them huh? lol
#34 |
Re: 1960 1 ton pics
I think i will have to change my lug nuts to run them. Agreed.
#35 |
Re: 1960 1 ton pics
So this happened after I bumped the valve cover with a rubber mallet.......I WILL NEVER DO THAT AGAIN!
#36 |
Re: 1960 1 ton pics
Awwww man, that sucks. Hope its not too bad of a pain to clean up.
#37 |
Re: 1960 1 ton pics
It...Im not quite sure how long it took. I was lucky and rigged a shop vac i got 90% or more of it all re oiled everything...except for all that goo/dried goo. The top of the head was perfect no sludge...
#38 |
Re: 1960 1 ton pics
Glad the mess cleaned up! Have you decided on a set of mirrors? Sorry if I missed something...
#39 |
Re: 1960 1 ton pics
Nope, you didnt . I did look at some mirrors. I figured that would be later though I have to fix the half melted rats nest under the dash. I plan on doing it this saturday. I will totally post a picture...If i can get it to run in the same day I will try to post a vid.
