#651 |
Re: 68 aka "Chained in Porterbuilt Prison"
I like that!
-Rus |
#652 |
![]() Join Date: Mar 2011
Looks sweet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#653 |
![]() Join Date: Mar 2010
That looks very clean and factory like. Nice work.
#654 |
![]() Join Date: May 2007
Now I can see it, that's slic.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#655 |
![]() Join Date: Nov 2008
looks great body work will be fun around the script.
#656 |
I like the small script,what is it off of?
#657 |
![]() Join Date: Apr 2007
still got a little left...there is a slight long "bump" above the h-e-v-r that i have to address..was there from original ....no welding on this piece....it's so thin that this "distortion" was unseen until primer.....I'll get it though.....it's too neat to quit now.....Can u see what this would look like as a fender script?? So subtle and yet makes everyone go HUUUH??......Thinking i may cut the paint on the script back to bare metal after basing the entire gate...bonding clear over script..then clear whole gate...will give that "brushed " look.......jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 Last edited by jtp67-72; 11-20-2013 at 11:20 PM. |
#658 |
Early Chevy small block valve cover....here's when i installed....And yes I stole this idea from a couple "unnamed" board members....lol....(HINT....ONE IS NOW NAMED MR. SEMA)........jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 Last edited by jtp67-72; 11-20-2013 at 11:19 PM. |
#659 |
Very Cool.....
LEFT LANE IS FOR PASSING!!!! SLOWER TRAFFIC KEEP RIGHT!!!! My C20 & Cars... http://67-72chevytrucks.com/gallery/...&ppuser=111212 |
#660 | |
Still Learning
#661 |
67cheby
![]() Join Date: Sep 2008
love it, they should have done this from the factory..they had the stamps, why didnt they ask us ! LOL
#662 |
Ok guys....here's the frenched panel I've been wanting to debut....always hated the way most just leave this 8" section behind tailgate either flat paneled or open on raised bed trucks....Have had this idea in my head for years.....may have been done by someone but i haven't seen it.....see what u think and it is pre-made by the way....well sort of!!....jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
#663 |
Here's a shot with all braces installed...the top of that rear panel is same as cross brace turned up..then 1" angle welded to backside for floor support...the new panel is bolted in to it and the lower cross sill....notice the little rounded cuts at ends of upper cross sill....for tailgate rib clearance.....
#664 |
Now a hint of where the panel came from.........................Anybody????
#665 |
I thought that panel looked familiar. Very nice work!
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#666 |
Hey Jim,love the panel piece and nice job on the clearance of last sill....Jim
#667 |
That's a pretty cool idea. I guessed the tailgate panel before I scrolled down, wasn't sure until I saw the cuts on the gate though. I like it!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#668 |
The weird thing is it was the exact width I needed and keep all the lines of the panel intact...usually doesn't work out...I don't have tools to make a panel like that ...so this was the alternative.....81-up Square body gate with handle welded up by the way...did welding and body work before cutting panel out...lot's easier and less chance of warpage...another cool thing is that all of the "cut" edges are hidden behind upper and lower sills except for ends which will square up nicely............jim
#669 |
67cheby
looking great !
#670 |
Very nice !! Lots of great ideas!
#671 |
Tot Roddin'
I like it....
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#672 |
Still Learning
Very cool and original idea. I've never seen it before. Nice!
#673 |
Great idea! Turned out awesome.
-Rus |
#674 |
Another feature that could be done with this is in the recess a trick gas cap could be mounted...I decided to use the side marker lite for 2 reasons..now that floor is raised the side marker is completely exposed on back side giving full "straight" access to tank bung...Also if u mounted the cap in the recess I think it would not be high enough for tank bung to fill properly....it's close and would work well if u left tank hanging down between frame rails but i'm having it made flush or near flush to bottom of rails...Yes another one of my "analism's".....can't take the tank hanging like it was an after thought!!
After lot of thought I'm leaning toward leaving the original tailgate handle...even bought the solenoids....but i'm leaving side markers,handles (although Camaro ),and putting trim back on.....truck is so low , handle (although ugly) shouldn't stand out ....well see....need to get moving on this project so less changes is better right now...Don't want to break the 7 year record of 67cheby!!............Mike u know I'm kidding!!!!!! By the way ...look at the bottom edge of this tri-plus gate...that's not the camera .....it is that crooked....heavy metal for a repop but man...........
#675 |
Got the air tanks and compressor mounts installed...............Nice brackets there Mr. Porter..................
