11-19-2013, 11:09 PM | #26 |
Re: 72 GMC Short Step Build
As a truck guru and have owned several high end trucks I consider my self an expert in the field of trucks
there is several thing actually many things wrong with this truck it ugly and the other cars you listed ,are anything like this is going to look like you have to sell them you are giving a bad name to all car guys like my carbs are in not TPI there is 4 different color black in engine bay I do not see but one wrong color on engine block one shade to lite the steering wheel what a joke they did not make an SS truck that year the radiator shroud you obviously did not do your self , very misleading THE ONLY MAN THAT CAN DO THAT KIND OF WORK IS "THE DICE MAN"!!!!!!!! you need to move the motor forward for better burn outs because of that lame and low powered motor "68 Z28 I had in high school" a clone and the vin # was off by two #s Call me for help or THE "DICESSSSSS MAN"before you destroy a good truck I cant take this anymore |
11-20-2013, 12:29 AM | #27 | |
PS: Spell check is your friend
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i Last edited by Z10; 11-20-2013 at 12:48 AM. |
11-20-2013, 01:04 AM | #28 |
Oh snap!!!!
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
11-20-2013, 01:55 AM | #29 |
Chris I love you man you know I could not resist and my spell chk is not working and ask dice man it was 4 gauges with tie wraps that gauge kit made me famous. call me , going over to dice mans for my input
PS. that was one bad 55 10.5 car and Ducatis are the ferrari of motorcycles Last edited by lotis man; 11-20-2013 at 02:12 AM. |
11-20-2013, 02:11 AM | #30 | |
I still think it was closer to 18 gauges? And I forgot about the tie wraps.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
11-20-2013, 02:16 AM | #31 |
you know me somebody would have said something bad and set me off LOL
I wish I kept my 54 PU |
11-20-2013, 02:20 AM | #32 |
I wish you would have kept my 68 Camaro!
11-20-2013, 02:20 AM | #33 |
Maaaaaaan! I was already popping the pop corn too..... sigh..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-20-2013, 02:30 AM | #34 |
beer?
11-20-2013, 03:03 AM | #35 |
11-20-2013, 03:21 AM | #36 |
Ok Ok, but i'd have to wait till i get home from work... That looks like a Guinness Z10.
11-28-2013, 06:20 PM | #37 |
Stainless Frame Fuel Lines
Car Boss has pretty much completed the fuel system. Here are some pics of his handy work. Fuel lines, Internal Fuel pump, etc.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i Last edited by Z10; 12-09-2013 at 11:17 PM. |
11-28-2013, 06:22 PM | #38 |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i Last edited by Z10; 12-09-2013 at 11:18 PM. |
11-28-2013, 06:29 PM | #39 |
Time For Testing The Surge Tank.
No Drips, No Runs, No Errors! Car Boss designed, fabricated, and completed and it works as designed. [IMG] ://i20.photobucket.com/albums/b213/wtz10/20131118_133102.jpg[/IMG]
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i Last edited by Z10; 12-09-2013 at 11:19 PM. |
11-28-2013, 06:38 PM | #40 |
Hidden Fuse Door
Double E, is building a new wiring harness and the decision was made to add an additional fuse panel and locate it on the passenger side above the vintage air main unit. Rather than remove the glove box to access the fuse panel, Car Boss cleverly made a hidden door in the back of the box. It's the little things that make this fun.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i Last edited by Z10; 12-09-2013 at 11:20 PM. |
11-28-2013, 06:44 PM | #41 |
Vintage Air High Pressure Switch Add
Double E also suggested a high pressure switch be added to the Vintage Air set up, so Car Boss added this little addition.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i Last edited by Z10; 12-09-2013 at 11:21 PM. |
11-28-2013, 07:03 PM | #42 |
Back Cab Wall Heat and Sound Insulation
My iphone was draining power and I had it swapped for a new one. Unfortunately I think I lost some pics of the cab sound deadening project. The firewall and toeboard was covered first with Dynamat, then a layer of aluminized closed cell foam and last Mass Load Vinyl. I do have several pics of the back wall which was completed yesterday. Can't see the Dynamat, but it's under there. You'll notice an upper strip of the aluminized foam, then the MLV, and last a small carpet strip just below the window. We need to get this finished so that Car Boss could finish up the fuel line connections. So, we're starting to finally put things back together. All my nice sound deadening is now covered up by the gas tank. Hopefully this will help quite the cab down. Still need to finish the floor, but that can wait until we finish everything under the dash.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i Last edited by Z10; 12-09-2013 at 11:23 PM. |
11-28-2013, 07:56 PM | #43 |
Re: 72 GMC TPI Short Step Build
89 Corvette Cruise Control w/resume
Cruise control, we got to have cruise control! So......... I purchased a cruise control lever from a 84-89 Corvette, complete with resume function. The only problem is this lever was not designed to attach to a 72 column. Car Boss to the rescue! Starting with this: To this:
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i Last edited by Z10; 12-10-2013 at 01:25 AM. Reason: Change title |
11-29-2013, 01:30 AM | #44 |
How do you dream this kinda stuff up?? Awesome work!
11-29-2013, 02:26 AM | #45 |
Stay tuned. More to come.
11-29-2013, 03:30 AM | #46 |
Well done so far.
11-29-2013, 12:46 PM | #47 |
What can you tell me about this tool? Some kinda vice mounted flaring tool? Brand? model?
11-29-2013, 12:48 PM | #48 |
Okay, now I'm hooked.
I'm in |
11-29-2013, 02:14 PM | #49 | |
It is an Imperial Eastman flaring tool #2000FS. It can be used in a vise or handheld and will do single, double, 37 degree, and 45 degree flares as well as swaging. They are very expensive, but if you do a lot of flaring or work with stainless steel like I do it is worth it. I have had mine for 15 years or more and I think it was approx. $200. I see that they are over $400 now, although I did see that one sold on Ebay recently for less than a $100. I also used it on the A/C switch on Z10's truck. |
11-29-2013, 10:17 PM | #50 | |
