![]() Join Date: Sep 2005
started to run fuel lines
got down to my last fuel line and i dont know what i was thinking but i cut it 2 short totaly upset with my self the long run from front is done as is the return side. i was really hoping to hear it run to day but i was also missing one fitting
so i had to order another 3 foot of line 20 buxs they where also out of the blue and red fittings i was using so i ordered a black one cause they had it in stock
meowMEOWmeowMEOW
Re: started to run fuel lines
I feel ya truckdude. I wanted all black fittings, and ten minutes later I threw that Idea out the window. Sadly, unless you want to order EVERYTHING from someone $$ like Aeroquip, you'll end up getting stuff from a few different companies, and at some point, it won't match.
I knew a dude who went and had all his fittings anodized purple to match, but can't say I would ever go to that length myself.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
When I did mine I bought all steel braided teflon lines thinking it would hold up longer than steel braided rubber. Didn't know that you need specific fittings for telfon... Instead of getting all new fittings I just bought rubber line. Still wasted $50 or so though.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
billett i did the same thing but summit let me send them back and order the right ones
I had already cut the line and tried to thread the fittings. It kept leaking and I couldn't figure out why for the life of me. I thought I just sucked at making fuel lines haha
![]() Join Date: Jun 2006
So how short was the line from where you needed it? If it was more than a foot and you had left overs from when you cut it. You could have just put 2 more fittings on with a flare union if that was a cheaper route to go.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
2 more fitting plus a flare was like 35 dollars i just ordered the missing fitting an 3 ft of hose for 34 dollars
I am sure another fuel filter would have been much more money, but would have taken up the slack
Sucks having to buy parts twice, but that's how you learn I guess!
On a side note, not to be negative, but you do realize putting your fuel filter where you have it will require you to drop the tank or pull the bed to service it when the time comes, right? Just throwing that out there because these filter/regulators do go bad from time to time.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Yes i do didnt think it allthe way though before i did it only after i cut the lines and hooked it up
