Old 10-14-2013, 10:13 AM   #1
bigblue 72
power window kits & brakes
Are the any true bolt in power window kits for all 4 windows?
Also considering upgrading to hydroboost brakes. What are the better donor parts or kits to go with?
bigblue 72 is offline   Reply With Quote
Old 10-14-2013, 01:59 PM   #2
jorgensensc
jorgensensc's Avatar
Re: power window kits & brakes
Not that I have found. I called one of the companies that others recommend that is a bit more expensive, and they don't have any for the rears. I offered them my suburban for R&D, but they didn't seem too interested. I may hit them up again. I remember it was going to be expensive, but supposedly they were one of the best out there.
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 10-16-2013, 09:43 PM   #3
305a
305a's Avatar
Years ago, before P/W kits were available I took to regulators, removed the cranks, built a bolt on motor bracket, added a GM power window motor and I had working P/W for my Chevy Truck. I plan to do mthe same for the rears on my Suburban. I plan on starting this fall. If anyone is interested I could do some type of write-up.
Mike
305a is offline   Reply With Quote
Old 10-16-2013, 11:01 PM   #4
rocknss
rocknss's Avatar
I'm interested!
rocknss is offline   Reply With Quote
Old 10-17-2013, 01:33 AM   #5
53burb
53burb's Avatar
Interested!
53burb is offline   Reply With Quote
Old 10-17-2013, 01:51 AM   #6
MSHax
MSHax's Avatar
Don't think I've seen an all 4 window kit. I know Nu-relic sells the fronts, I'm sure they can do the backs as well. I have used them for a few projects, their instructions seem to be crap, but the products are great.
I stopped adding up how much I spend on my builds, it only makes me doubt my sanity knowing I've spent more than 9 times it's original value new.
MSHax is offline   Reply With Quote
Old 10-23-2013, 01:29 PM   #7
68 TT
Still plays with trucks
68 TT's Avatar
As far as the hydroboost you want to look for the booster from the 1-ton trucks as it is heavier duty than the one from the Astro vans. Many people who started with the Astro unit end up switching.
The hoses from a square body will fit and work well, are inexpensive & easy to find new. Just avoid the later model ones where they decided to run the hoses straight down into the gearbox instead of with a 90 degree bend like the older ones. They won't clear our inner fenders without cutting.
You can get the hoses from a flared fitting or O-ring fitting application to match your hydroboost donor. You will need the steering gearbox to match so you can avoid expensive custom pressure hoses to go from one to the other.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 10-23-2013, 01:34 PM   #8
68 TT
68 TT's Avatar
Mike
I would like to see a write up of what you did.
I have been wanting to build a kit from common square body parts for quite a while and have all the pieces needed plus a spare set of doors to play with. Just need the time to get to it. Being a machinist & welder / fabricator it shouldn't be too hard once I pull the door skins off the shells. Hopefully I can get to it this winter.
I want to figure out a way to get the square body power lock parts to work on our rigs too.
Old 10-23-2013, 02:18 PM   #9
jorgensensc
Specifically which 1 ton trucks work and mount like the astro van?
Since you have all the stuff, could you look and see if a set squarebody or '90s power window regulators could mount up inside our doors somehow?maybe using some spacers or something?
Old 10-23-2013, 05:00 PM   #10
john
member #16
john's Avatar
I wonder how hard it would be to adapt a-1 electric kits for the other windows. They look pretty simple.
http://www.a1electric.com/Merchant2/...ct_Code=GM49-K
john is offline   Reply With Quote
Old 10-23-2013, 06:11 PM   #11
DWilbur
Check out the build thread on making your own power windows from one of the members.
http://67-72chevytrucks.com/vboard/s...d.php?t=601167
DWilbur is offline   Reply With Quote
Old 10-23-2013, 09:42 PM   #12
305a
305a's Avatar
I am a collision repair teacher at a career center, and I have one of my students working on the rear power window problem. I spent a few minutes helping him on it today. I hope to have some information in the next few weeks. Mike
Old 10-25-2013, 08:36 AM   #13
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I called Nu-Relics a few years back and they said they would do the rear if I sent them my regulators. They quoted around $500 back then.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 11-08-2013, 08:45 PM   #14
305a
305a's Avatar
I had two of my students working on this most of the week. They were not able to fit the motor between the door shell and window. It looks like there is less room in the rear than the front doors. I will let you know if we find a way to fit the motor it the door.
Mike
Old 11-08-2013, 09:25 PM   #15
Bigdav160
Bigdav160's Avatar
I might take this up this winter. I successfully made front power regulators from the post in the truck forum.
I keep my Suburban at work but plan to take it home in December
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-20-2013, 02:31 AM   #16
68 TT
68 TT's Avatar
Mike
There are a few different motor shapes in some of cars I have come across that could work. The ones from an Astro van may be more compact than the square body versions or be a shape that can be made to work more easily. Pretty common donor too.
The 88-98 truck part may be more compact as well.
Old 11-20-2013, 02:34 AM   #17
68 TT
68 TT's Avatar
Square body 1-tons are the easiest to work with and many of the parts in the system will fit our trucks too.
Old 11-20-2013, 02:43 AM   #18
68 TT
68 TT's Avatar
That was my plan for this winter if I can get to it around the higher priority projects that must get done.
I doubt it will be that easy though or somebody else would have done it already. I figured it would take cutting apart both sets of regulators and making a hybrid part with the right configuration to fit inside the door of our trucks. We will see.
Old 11-20-2013, 05:45 PM   #19
ERASER5
ERASER5's Avatar
I guess locking the crank stub into the chuck of my DeWalt cordless drill is not considered "high tech." Duck tape helps thing stay in place.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 11-21-2013, 04:22 PM   #20
boostat4500
I have Electric-life window regulators in the front and rear of my burb'. They bolt right in to the rear door but you have to shorten the arms a little for the window. Works great but the windows only go down about 4" shy of fully open. Not that big of a deal in my opinion.
I also run a hydroboost out of an 02' 3/4' ton chevy. I made my own lines to the pump and steering box, but its pretty easy and works great.
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc.
boostat4500 is offline   Reply With Quote
Old 12-13-2013, 06:42 PM   #21
Bigdav160
Bigdav160's Avatar
I'm here to inform y'all that bonnieclyde100's design, from the link above, works fine for the rear windows. Other than having shorter arms, the difference from the front regulator to the rear regulator is the gear is not centered to the arm. (15 teeth to one side and 20 to the other).
No matter as I made adjustments to the design. When repositioning the gear 90º I used the rivet holes as the reference. I also used a plasma cutter to make a tighter, nicer looking motor bracket. It made the whole thing go into the door easier as there isn't much room to get past the lower window stop. I also nicely cut out, reattached and reused the crank pilot/guide to the new motor bracket. I have full window travel.
I installed the regulators today and they work slick. Unfortunately I forgot to take pictures. I thought I took a couple pics after I painted the regulators but apparently not
When I go back to the shop I'll bring the camera so y'all can see how nicely the motorized regulators fit.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 12-17-2013, 03:18 PM   #22
jorgensensc
Thank you for the update!! Any Pics would be great!!! Thank you again!
Shawn
