11-20-2013, 12:09 AM | #1376 |
Re: 1969 Short Wide
I'm envious! Any scuffin between the clear coats? Are you still going to cut and buff that?
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
11-20-2013, 12:11 AM | #1377 | ||
Still Learning
Re: 1969 Short Wide
I also think photobucket is killing the resolution on the pics when I upload them. |
11-20-2013, 02:54 AM | #1378 |
Re: 1969 Short Wide
Hey Mike! I'm fixin' to get ready on choppin my bed sides and wondered if you could sneak me a couple photos of them square holes along the bottom (spacing). Up at #1353 there's a good view of the row in front of the wheel tubs but I can't quite make out the ones behind. I'd like to take my sections where I can cut out some crud in the skin but want them holes to wind up where they oughta be. Not that I couldn't fill any wrong ones and make new ones, but it'd sure be easier to just section it just so. Paint is really looking good man. My eyes are peeled on the assembly and final. I think you've changed my way of thinking on how to go about it.
11-20-2013, 09:32 AM | #1379 | ||
Still Learning
Re: 1969 Short Wide
No scuffing between coats on the clear. "Most" activated paints and clears can be top coated up to 24 hours before scuffing is required. Quote:
11-20-2013, 10:51 AM | #1380 | |
Re: 1969 Short Wide
What prep did you do? Love what I am seeing on your thread!
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
11-20-2013, 12:06 PM | #1381 | |
Still Learning
Re: 1969 Short Wide
As far as prep goes, I used 220 grit on a DA sander where I could reach and the red 3m scotch brite everywhere else. The light gray primer is Matrix epoxy and the dark gray is Omni epoxy. On the bed floor (top side) I painted it with the same bc/cc that I'm using everywhere else. I did this so there would be no issue with gray spots. I know now the tinted covers good enough to skip this step.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 11-20-2013 at 12:28 PM. |
11-20-2013, 12:24 PM | #1382 | |
Re: 1969 Short Wide
11-20-2013, 01:52 PM | #1383 | |
Still Learning
Re: 1969 Short Wide
Awe, bringing back some good memories of my exhaust fabrication. On the custom parts, It is a fringe benefit that comes with the this job. I don't like farming out anything I can make for the most part. Sometimes I just buy parts that are easily made. Sometimes I make things that are cheap to buy. |
11-20-2013, 02:11 PM | #1384 |
Re: 1969 Short Wide
You just showed me a use for the hardened, unground V-block I have had in the bottom of my tool box since college!
Seriously, you do nice work and come up with some nice solutions to problems! I enjoy watching and learning!
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
11-20-2013, 02:26 PM | #1385 |
Re: 1969 Short Wide
X2! Nice fab work!
What do you reduce Raptor with? Do you need to do that where you want it "pretty"?
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
11-20-2013, 02:55 PM | #1386 | ||
Still Learning
Re: 1969 Short Wide
I think, and I may be wrong but it seems temperature sensitive too. The cooler temps like we have had lately make it less "pretty". It's pretty thick anyway but when it's 95 in the summer it seems to flow and lay prettier. Ya know. |
11-20-2013, 07:43 PM | #1387 |
Re: 1969 Short Wide
I'm almost sure I did, but if I didn't comment back when you posted them exhaust fab photos - stellar work!
11-20-2013, 09:45 PM | #1388 |
Re: 1969 Short Wide
Awesome exhaust mounting idea! Wanna come to the Houston area and do mine?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
11-20-2013, 10:07 PM | #1389 |
Re: 1969 Short Wide
X2 to that, i have unground and also my good ones.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-20-2013, 11:31 PM | #1390 |
6>8 Plugless........
Re: 1969 Short Wide
It sure would be nice to have a mil and a lathe in the shop. A guy could make all kinds of things with those 2 (expensive) tools.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-21-2013, 01:30 AM | #1391 | ||
Still Learning
Re: 1969 Short Wide
Thanks. I have some big ones 6" I think, those would bend some longer parts. I have a nice little lathe in my shop still looking for a bridgeport or copy to stick in there. No where to put it right now even I did find one. But I have access to about any kind of machining center at work |
11-21-2013, 02:01 AM | #1392 |
Re: 1969 Short Wide
Those custom hangers are nice looks super
project: "my happy mess" |
11-30-2013, 11:50 PM | #1393 |
Still Learning
Re: 1969 Short Wide
12-01-2013, 12:04 AM | #1394 |
Still Learning
Re: 1969 Short Wide
Finally got past the backward steps.
Had to touch up some more sand through and re-clear on the bedside. Warning: don't sand through your clear coat, it's a pain to fix..... Bed assembly begins: Fitting the tailgate: Prepping the tailgate for paint: |
12-01-2013, 12:06 AM | #1395 |
Laid Back
Re: 1969 Short Wide
Great work mike!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
12-01-2013, 12:58 AM | #1396 |
Man of Mini-Talents
Re: 1969 Short Wide
Lots of little things add up to a lot. Love seeing it come together.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
12-01-2013, 01:01 AM | #1397 |
Re: 1969 Short Wide
I am loving that bed!!!
12-01-2013, 01:31 AM | #1398 |
Re: 1969 Short Wide
I guess a lot of these paints can be sprayed right over the clear and then be re cleared again, so i hear anyway.. Your doing great work!
12-01-2013, 09:29 AM | #1399 |
Re: 1969 Short Wide
Looks awesome Mike
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
12-01-2013, 09:43 AM | #1400 |
Re: 1969 Short Wide
Dang... Looking really good Mike.. If you are working this week on it I will come out and help you/hang out...
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
