11-21-2013, 09:15 PM | #1 |
Normally closed brake lever switch
If anyone needs a normally closed lever type brake switch for a cruise control or torque converter lock up switch or whatever, this is what I did. They make the lever type brake light switches in a left and right hand version.
I bought one of each and gently bent the retaining tabs until they came apart. Swapped the contact plates and reassembled. I had been using a micro switch for the cruise control redundant disengage, but it was not up to the job. A relay could be used but that would have required hacking into the wiring harness for power. This provides a robust vintage style switch with no need for extra wires. |
11-22-2013, 09:48 AM | #2 |
Re: Normally closed brake lever switch
That's interesting, I didn't know there were two versions of this switch.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
11-22-2013, 12:21 PM | #3 |
ingenious
i wonder how hard it would be to break a contact out, drill a hole and epoxy a third contact into a new switch. this would allow one switch for both uses. i used the relay set up.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
11-22-2013, 12:58 PM | #4 |
[quote=_Ogre;6383147]ingenious
i wonder how hard it would be to break a contact out, drill a hole and epoxy a third contact into a new switch. this would allow one switch for both uses. i used the relay set up. I too considered that option. Also, I was wondering if there is anyone making a NO/NC version. |
