Old 11-10-2013, 02:10 AM   #1
carolinasled
carolinasled's Avatar
Lowered my 85 Today
Here is my 85 I lowered today.
2.5" Mcgauphys spindles 1 coil cut, Specialtyretail's Flip bracket and Shackles. 2" on pass and 1" on driver.
Spindles hit the wheel weights so I used a Mr gasket 7/32" Spacer on the front.
Notch and New Shocks hopefully this week, Not a Daily. Smaller Tires Soon.
Wheels are Summit Racing 15x8 4.25 BS
carolinasled is offline   Reply With Quote
Old 11-10-2013, 02:48 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Lowered my 85 Today
Looking good!!
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 11-10-2013, 02:51 AM   #3
y5mgisi
Second Chance Program
y5mgisi's Avatar
Very good!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 11-10-2013, 06:33 AM   #4
kikkegek
kikkegek's Avatar
looks sweet! good job!
kikkegek is offline   Reply With Quote
Old 11-10-2013, 04:11 PM   #5
Malo83
Cruzzzn' Vet
Malo83's Avatar
Malo83 is offline   Reply With Quote
Old 11-10-2013, 07:12 PM   #6
NASTY-LSX
Looks great, does not look bad with those tires either.
NASTY-LSX is offline   Reply With Quote
Old 11-10-2013, 07:14 PM   #7
jitteryguy
GoatLube Experss
jitteryguy's Avatar
looks good .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 11-10-2013, 09:34 PM   #8
Claytona08
Claytona08's Avatar
Clean truck
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 11-13-2013, 04:30 AM   #9
franky69c10
chevy runs deep
franky69c10's Avatar
Looks good bro
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 11-13-2013, 09:51 AM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Go to a 255/60R15 tire. Should fit just about right.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 11-13-2013, 03:07 PM   #11
sc85k-10
sc85k-10's Avatar
Looks good Ryan
sc85k-10 is offline   Reply With Quote
Old 11-14-2013, 09:06 AM   #12
carolinasled
appreciate it Wally
Old 11-14-2013, 03:40 PM   #13
melks
melks's Avatar
looks good!
1984 Chevrolet C10
melks is offline   Reply With Quote
Old 11-14-2013, 03:52 PM   #14
custom97
custom97's Avatar
Looks good low.
'86 C10 swb 5/5 drop
http://67-72chevytrucks.com/vboard/s...55#post6239155
custom97 is offline   Reply With Quote
Old 11-14-2013, 03:56 PM   #15
JWall
Frequent Flyer
JWall's Avatar
Looks good!
- Justin
1 Owner 1976 SWB
Old 11-24-2013, 03:21 AM   #16
carolinasled
So I replaced the front tires with 235/75s, Removed the spacers(Had to grind the spindle at the tire rods a tad and the LCA a little more). I installed shocks on it and need to lower the rear mount about 2". I swore I read someone used front shocks on the rear, So I picked up some and they are about maxed out at ride height. So when It compresses its ok but when it goes back up it locks out.
Old 11-24-2013, 05:26 AM   #17
Tuff 1986
Tuff 1986's Avatar
Nice truck.. I have a question for you, I have a flip kit in the back and still have the chevy lean.. I noticed on your post you put shackles on.. And lowered it 2in on passenger side and 1in on the driver side.. Did you do that because of the lean and did it fix it..
Will I ever finish my 1986 stepper..
Tuff 1986 is offline   Reply With Quote
Old 11-24-2013, 11:05 AM   #18
Sodell
Sodell's Avatar
I used a set of 79 Toyota truck rear shocks. The stock Toyo's are 19.5" extended and 12" compressed. The Chevy's are 22" and 14". They work great.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 11-24-2013, 02:02 PM   #19
carolinasled
Do you reckon the angle of the shock with a flip kit makes it harder to compress on the stroke? I have thought about making a crossmember and mounting the shocks vertical behind the axle. Maybe even install air shocks that I have.
This 85 Chevy with the drop kit would look A hell of A lot better with you up in it.
Old 11-24-2013, 09:00 PM   #20
Old School Low
Old School Low's Avatar
Help me out. Im just about ready to do this to my short 78 C15. No notch yet? Maybe just shackles so far? Are u using ANY shocks at the moment? And..did u cut exactly one coil? Anyway, you're lookin good.
Old School Low is offline   Reply With Quote
Old 11-24-2013, 09:57 PM   #21
Sodell
Sodell's Avatar
I think you would still want them at the same angle. BTW truck looks nice, like the two tone white and red.
Scott
Old 11-24-2013, 10:58 PM   #22
rs74
rs74's Avatar
I kind of like it with the tires in the pic. That is one good lookin truck. Is that Apple red?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 11-25-2013, 01:25 PM   #23
rudey737
The truck looks great. I have a 4.5/6 McGaughy's ready to install on my truck, but I've been waiting on doing it to rebuild some of the the front end. Did you install new upper & lower ball joints? Did you install new inner and outer bearings?
Azulita - 84 Chevy Scottsdale Longbed 305/350
rudey737 is offline   Reply With Quote
Old 11-25-2013, 02:27 PM   #24
UATahoe
Love the look. Curious about the spindle clearance issue. Do you think this would still be a problem if you are using the stock rally wheels? I was planning on running the same spindle for a 2.5/4 drop. I have 30.5" tires right now though and was worried they would be an issue after lowering.
UATahoe is offline   Reply With Quote
Old 11-25-2013, 06:19 PM   #25
carolinasled
I tried that but it helped out only a little.
I actually trimmed the passenger coil more. I took out 1/2 coil and now its a hair off to the passenger side with a Tape measure, A lot harder to see by eye. I believe its different for each vehicle. I made marks on the spring before I cut it 12, 3, 6 and 9. I started off cutting a 1/4 coil and that wasnt enough so I did another 1/4 and left it.
