Old 11-25-2013, 04:01 AM   #1
79bonanza
4l60e to np241 4 Lo question
Ok guys I'm swapping a 99 5.3 4L60e In to my 91 k5. I'm going to run my same np241 transfer case. I was just wondering if my trans and engine are gonna freak out when I put the transfer case in low range and it changes the vehicle speed but won't change the gear or rpm. Won't my trans think it's slipping.
I know new transfer cases have a speed sensor on the front drive shaft as well and a sensor letting it know it's in 4 lo
So what do you guys think
79bonanza is offline   Reply With Quote
Old 11-25-2013, 11:17 AM   #2
Bigdav160
Bigdav160's Avatar
Re: 4l60e to np241 4 Lo question
The ECM needs input from the transfer case so to know when you've engaged 4WD-LO
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-25-2013, 03:34 PM   #3
79bonanza
Ahh ok, do you know if it's just a simple ground switch or is it like a speed sensor. If it's just a ground switch couldn't I just run it to like a brake witch setup on my shifter housing.
Old 11-27-2013, 11:45 AM   #4
Angryman117
Check out LT1SWAP, they have the PCM pinouts listed that you will need to use.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
