12-14-2003, 11:57 PM | #1 |
Windshield washer pump won't work
OK my windshield washer pump isn't working. This is my fourth truck between 69-72, and none of them have had a working washer pump, so I am pretty sure this is a common problem. I would rather stay with the factory pump, and not one of the aftermarket add-ons if its feasible.
What is usually the problem with these factory ones? I have seen a rebuilt one in the LMC catalog. Will this do the trick for me? When I push the switch in I can't hear any sounds. I got under there today and it looks like everything is hooked up properly. This is my 3rd question in the last 10 minutes, not trying to hog the board, just had a long day in the garage -
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
12-15-2003, 12:01 AM | #2 |
newly minted old timer
those rebuild kits work fine, they are just like the orginal. too bad the orginal one sucked! i have never seen a working one.
i always go with the aftermarket pump. works perfect, easy to put in. i am like you though, i do like to keep things orginal. almost everything on my truck is stock. 2 things though that i will always change, hei and a washer pump.
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
12-15-2003, 12:26 AM | #3 |
im trying to figure out where the lines go through the firewall to the washer pump from the lines in the cowl?
70 longbed 496/th400/Ford 9" |
12-15-2003, 01:16 AM | #4 |
its all about the +6 inches
I've seen one that worked. even though i was impressed with the fact that it worked...I was not impressed with the performance.
I'd say get an aftermarket one. |
12-15-2003, 04:01 AM | #5 |
lol, i need one of those too...I am tired of having to grab handfuls of wet snow and wiping it on the windshield when I am stopped to clear the salt spray off.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
12-15-2003, 08:10 AM | #6 |
CCRider
The problem with the factory pump, (besides being a poor design) is pumps are designed to push not pull. There is at least 4 feet of hose between the bottle and the pump. The pump is about the same height as the bottle so it does gravity feed very well, so the system usally needs to be primed if it runs dry. You can get the factory pump to work,but if you want a clean windsheild get an aftermarket one.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
12-15-2003, 10:43 AM | #7 |
Designated A-hole!
I have a tank with the pump from a 92 s10 with the pump in the bottom of it. I want to use it for my washer and use my old washer bottle for an overflow tank. Will this work? Where can I get a cap for my factory washer bottle that I can connect a large enough hose for the overflow?
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
12-15-2003, 11:28 AM | #8 |
12-15-2003, 11:32 AM | #9 |
Robert Olson Transport
before you go buying parts id check the wiring to it and the fuses the switch too lots of times its a wiring issue
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-15-2003, 11:44 AM | #10 |
Beer Power!!!!!!!!!!
Hey, when I push the button on mine it makes a lot of popping and motor noises but no fluid comes out. I made sure water was coming through and also put one of those pump rebuild kits on it. What else could be wrong?
Rather be fishin' |
12-15-2003, 02:52 PM | #11 |
i was lucky enough to find a NOS pump at a chevy dealer. i had tried a rebuild kit before, but the piston pump itself was shot. the new one works, but i will agree that it is nothing spectacular. guess its just one of the joys of 30+ year old technology.
12-15-2003, 03:05 PM | #12 |
My washer pump has worked since the day I bought the truck. 10 years or so ago.
If you live where the temp can drop below freezing, NEVER put water in the reservoir. Always use the blue stuff. If you try to pump ice you'll ruin the pump.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-15-2003, 03:10 PM | #13 |
Formerly yellow72custom
Mine worked for a little bit....only squirted out the driver's side nozzle though
Then one day it would turn on whenever the windshield wipers were on. I simply empted the resivour and forgot about it. When i replaced my wiper motor i didn't bother putting in a new pump....i'm used to not having a pump so ignornace is bliss
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
12-15-2003, 03:50 PM | #14 |
Mine works but it if I use it then try to use my windshield wipers the pump keeps working til I shut down my truck
12-16-2003, 01:54 PM | #15 |
Try spinnin 4 rear tars
WOO HOO!!! Now mine sounds like one of the better pumps...
It pops and clunks but nothing comes out. If I get a mouthful of water and blow it into the hose that connects to the tank while the pump is on, then I can get something out of it. So after I prime the pump, it will work, squirting short bursts of fluid. But if it sits for a few hours, then all of the fluid runs back into the tank. Would a little rebuild kit for the pump solve this bad seal problem?!
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
12-16-2003, 02:04 PM | #16 |
I had the same problem, made alot of noise but nothing came out. The problem was the clog wheel that works the pump it had broken off and the rebuild kits don't give you a new clog, I got one at the junk yard.
1969 GMC S/B S/S 3" drop |
12-16-2003, 02:23 PM | #17 |
user # 2756
I bought a pump from mother truckers and it works like has been said, I originally installed the LMC kit but it was the piston seal that was bad and would not pull the water.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
