Old 11-27-2013, 02:28 PM   #1
Hogger54
Hogger54's Avatar
Fuel tank under front part of bed. Anyone done it?
Looking at building, or putting a fuel tank under the front half of a long bed. Probably building due to space in that area. Right behind the cab, and in front of the axle.
Anybody done it? Got pics?
Hogger54 is offline   Reply With Quote
Old 11-27-2013, 02:59 PM   #2
_Ogre
_Ogre's Avatar
Re: Fuel tank under front part of bed. Anyone done it?
panel truck gas tanks have always been next to the drive shaft inside the frame.
my panel has a 2nd home made tank located outside the frame that would work on a fleetside bed.
always wondered why tank manufacturers didn't reproduce the panel tanks for use in trucks.
you might be able to have one made
shop air compressor timer
Old 11-27-2013, 02:59 PM   #3
mr48chev
mr48chev's Avatar
Chevy did it in 47 and 48 and you can buy the stock tank and straps new. I'm not sure if the bracket that fastens to the frame to hold the tank is available though. I've thought about putting one back under the 48 since It will have a six in it and I can run both pipes down the left side.
From the asking price of new stock style tanks you might want to hunt down something that will fit where you want to put it though.
My ongoing truck projects:
Old 11-27-2013, 05:32 PM   #4
G&R's57GMC
G&R's57GMC's Avatar
If you have an open driveshaft be sure to put a loop around it near the front u-joint.
The last thing you want is a failed driveshaft wiping around punching holes in the fuel tank.
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 11-27-2013, 06:13 PM   #5
mr48chev
mr48chev's Avatar
That's a good idea even if you don't have a tank beside the driveshaft.
I saw that someone had the 48 style tank for a reasonable price the other day but can't find the link now.
Well maybe not that reasonable but this is what a stock 47/48 tank looks like.
Old 11-28-2013, 12:09 PM   #6
Hogger54
Hogger54's Avatar
Absolutely. I was figuring that into my plan.
Old 11-28-2013, 03:10 PM   #7
BlueJeep
BlueJeep's Avatar
I don't know what you've got for room between the frame rail and the driveshaft, but there should be plenty of junkyard candidates. Here's an s10 tank, I assume Rangers, Dakotas, Toyotas, etc all have tanks mounted here because they all use the space behind the axle for the spare tire.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
