Old 11-27-2013, 11:43 PM   #1901
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Finally starting my Longhorn 4x4 conversion
Sorry, I don't have any drawings of my cross members. I do have a template of a cross member I built for the V Rig, and I do have an Auto World cross member I can take pics of for you too.
Ryan
1969 Chevy milk truck
Old 11-30-2013, 02:43 PM   #1902
madhatterxlch
madhatterxlch's Avatar
Anything is helpful, if could come up a cad file then I could take it down to my local metal guy and put it on the plasma table.
madhatterxlch is offline   Reply With Quote
Old 12-01-2013, 04:10 PM   #1903
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Man....
Drive it don't take it apart....lol....Send that Orange Beast over to my house and i will drive it for you. Wicked ride you have and some awesome skills your truck is a Beast I really like your thread.
I been crazy busy but this is one of the first threads I had to check out when i got back.....I pick up my 24 valve next week so i can be a member of the "Darkside" too ....I might have a 12 valve set up now too...You guy's are a bad influence. So does anyone make a C&C cover so my die hard friends won't have to see that big C word across that cover?.......lmao
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 12-01-2013, 06:04 PM   #1904
ryanroo
ryanroo's Avatar
im not sure you will be able to hide the fact that it is a cummins. somewhat distinguishable sound they make. the 12v "cover" from dodge comes off and leaves just the 6 individual rocker boxes with no brand identification. in my feeble knowledge, i dont know of a 24v cover that doesnt at least say cummins.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 12-02-2013, 12:39 AM   #1905
jbclassix
Junk Yartist
jbclassix's Avatar
Ryan, I've seen some 24v engines in pushers that say SU!WWn) but I don't know what that means.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 12-02-2013, 08:33 PM   #1906
Dieselwrencher
Just mill off the Cummins letters and you will be good to go. Yeah, I know, but this truck is destined for change. If I keep letting my mind wander it might keep getting changes.
Ryan
Old 12-02-2013, 08:34 PM   #1907
Dieselwrencher
Sorry Dude, no CAD file here. I build my stuff the old fashioned way. Measure and mock up.
Ryan
Old 12-03-2013, 06:38 PM   #1908
6lcummins
Bet you or the other Ryan could build him a setup that would work...
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 12-03-2013, 10:05 PM   #1909
ryanroo
ryanroo's Avatar
oh he could build anything. but nothing he designed works for trucks that arent like his. and hes one expensive a-hole to have work for you.
72 K20 12v build
Old 12-04-2013, 08:52 PM   #1910
6lcummins
This coming from you....
"STOCK"
ASSEMBLY THREAD
Old 12-04-2013, 08:57 PM   #1911
ryanroo
ryanroo's Avatar
Just calling it how i see it...
72 K20 12v build
Old 12-05-2013, 08:45 PM   #1912
Dieselwrencher
Hey, my neighbor has a Duramax truck for sale. How about some change?
Ryan
Old 12-06-2013, 03:35 AM   #1913
jbclassix
Junk Yartist
jbclassix's Avatar
Something wrong with your cranium
-Jeremy
Rebuilding an NP205
Old 12-07-2013, 01:20 AM   #1914
rgreathouse
Maybe I missed it but what'd you end up with for the hood latch? Truck looks great by the way!
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 12-09-2013, 05:01 PM   #1915
Dieselwrencher
Thanks. We ended up moving the intercooler down to where it almost touches the frame. Then the hood latch will fit in there if you shim it up about 1/4". We had to cut my lower support on the bottom of the support and add some pieces to keep the strength in it.
Ryan
Old 12-09-2013, 08:22 PM   #1916
ryanroo
ryanroo's Avatar
you dont have to lower it that much! just move it back into the core support. trim as necessary...
72 K20 12v build
Old 12-10-2013, 04:07 PM   #1917
Dieselwrencher
I like how you make that seem like it's a 5 minute task. LMAO
Ryan
Old 12-10-2013, 09:43 PM   #1918
ryanroo
ryanroo's Avatar
only took a couple of minutes on the internet!
72 K20 12v build
Old 01-23-2014, 11:36 PM   #1919
Dieselwrencher
Here pretty soon the new transmission is going to be going in the truck. I'm going to be switching out my steering column and going to try to put it in closer to the firewall this time to gain some leg room. I've decided to just use an OEM column shift tilt column and leave the floor shifter for a manual truck. Now the biggest hurdle is to decide whether or not to leave the dodge D60 in it or switch to a ford HP D60 from a dude in Co? Choices choices
Ryan
Old 01-23-2014, 11:44 PM   #1920
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Here pretty soon the new transmission is going to be going in the truck. I'm going to be switching out my steering column and going to try to put it in closer to the firewall this time to gain some leg room. I've decided to just use an OEM floor shift tilt column and leave the floor shifter for a manual truck. Now the biggest hurdle is to decide whether or not to leave the dodge D60 in it or switch to a ford HP D60 from a dude in Co? Choices choices
Sweet score on the OEM 4spd tilt column, those are $$$$$ and rare. Then again, this truck is totally worth that kind of investment.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 01-23-2014, 11:47 PM   #1921
Dieselwrencher
Whoops, I worded that wrong. It has a 4 speed tilt in it now, and I'm going to put a column shift tilt column in it. I was just going to leave the floor shift column and put in an after market shifter. I changed my mind on that.
Ryan
Old 03-06-2014, 11:55 AM   #1922
Dieselwrencher
Project update. No work is being done, but I've been gathering parts to complete the auto swap and to get the truck daily driver ready. I bought a set of 33 12.50 16.5 BFG AT KOs, a Tcs billet input shaft, lokar locking dipstick, lokar throttle pressure cable, a double deep trans pan, a huge Hayden trans cooler, and I'm still going.
I have plans to relocate the batteries to behind the cab or under it, remove the stack and run exhaust out the back, I need to get my new rear bumper mounted and decide what color to powder coat it. I can't make my mind up on that. It's a toss up between white, an aluminum silver, or black. After a couple other projects are finished, I'll get back on this.
Ryan
Old 03-06-2014, 07:16 PM   #1923
mx289
mx289's Avatar
Thats gonna be a fun truck on the street.
Awesome truck.
Tom
mx289 is offline   Reply With Quote
Old 03-06-2014, 07:36 PM   #1924
6BT 56
6BT 56's Avatar
What sort of projects have you been up to ? I think you need to do a 02 ish gm 4X4 2500 swap for sumone so I can tag along and get the courage to rip our family truckster apart .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 03-06-2014, 08:54 PM   #1925
Dieselwrencher
Been parting out some trucks out trying to scrape up the funds to finish some projects. I've got a conversion on another 67-72 to do, and I started putting 2 turbos back on the Corvette. Just waiting on the correct waste gate to finish it. We've had some customer trucks and that has slowed personal projects down again. I'd do a newer chevy but not many people around here want to dump the money in one. They'll just go get a loan and buy a Dmax truck.
Ryan
