11-28-2013, 06:38 AM | #1 |
does anyone make doors like this for a blazer?
does anyone know a place thats makes doors like these for a 69-72 blazer?
70 SWB STEPSIDE 70 BLAZER 09 challenger |
11-28-2013, 01:35 PM | #2 |
Re: does anyone make doors like this for a blazer?
ive seen them done but they were custom made believe they had a write up in 4 wheel mag
11-30-2013, 02:48 PM | #3 |
K5drive
I have a set of doors that someone else started. I just haven't gotten around to completing them
12-01-2013, 03:45 PM | #4 |
SKINNY TIRES RULE!
I looked at a blazer for sale in Albany Oregon in the late 80's that had doors like that. I've seen two otehr Blazers for sale that had those same openings. My guess is there was someone making them in the 70's but they did not sell very many.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
12-02-2013, 10:38 AM | #5 |
Only ones I've seen are custom made from stock doors and cut down to where you want the half door to sit. Then use sheet metal across the gap and sand and mud as needed to finish and paint.
12-02-2013, 09:45 PM | #6 |
Unlike the Ford Bronco tub, the Blazer tub has a lot of movement and flex through the door openning. I imagine that the movement/flex of the Blazer tub quickly destroyed whatever aftermarket Blazer fiberglass doors that were out there. Probably why they stopped making them. Just a guess.
12-03-2013, 11:46 AM | #7 | |
12-04-2013, 02:24 AM | #8 | |
SKINNY TIRES RULE!
12-06-2013, 08:10 AM | #9 |
If you use stock Doors and cut them down they would be the same as Stock just have the cut in them and finish them. Fiberglass probably would Have issues If flexing the truck A Lot or rubbing against trees Or rocks Four bying.
12-06-2013, 08:06 PM | #10 |
If you cut down stock doors I don't think you would be happy with the outcome. You would have to reinforce them with tubing. If you just drive your blazer with out the hard top on it flexes the body.
12-07-2013, 01:20 AM | #11 |
If your rockers and rocker Boxes Are Junk or Rot has taken over in the door area it Would be a bigger Problem. But with stock doors they have internal support braces Already and to close them in after Cutting would be similar To boxing your frame for Less Flex. I've seen it done with not a lot Of problems. But a lot I've seen also Have a cage that keeps body flex to a minimum as well. You could cut down a stock door and add a one inch strut brace Across the opening to help with support and also keep somewhat a safer side impact protection. Or you could Buy a tube bender and make tube doors and skin them to have a solid Look. That way flex Wouldn't be a issue either.
12-12-2013, 12:27 PM | #12 |
That's the gas monkey garage bronco isn't it? Wish Rawlings would build a Blazer.
~ It's a Learning Process ~ Click Here for my Blazer Build: 1971 Blazer 4x4 Click Here for my Work Truck Build: 1970 C10 LWB Toys: 1970 C10, 1971 Blazer 4x4, 1976 Corvette Stingray L82, 2011 Cadillac CTS 6 speed, 2008 VTX 1800F |
12-12-2013, 02:50 PM | #13 |
Yep, saw it on Mecums too
