Old 01-17-2013, 10:57 AM   #1
Ironhorse
Ironhorse's Avatar
1971 K10 Rear Axle ?
Doing a swap on my '71 K10, orginally sm465/np205. Going to a 350TH/np205 which has created some issuses of changing slip yokes and such. Nothing time and money hasn't been able to overcome. As I was under the truck I scraped and cleaned the rear axle housing and found the following:
TAY W 3642 stamped in the top right side of the rear housing. Can someone fill me in on the rest of the axle code? I have a Red Book that shows TAY as a 3.07:1 ratio. Running 31x10.50x15's on 8'' rally wheels. Being a 4x4 I would have thought it would have a taller gear such as a 3.73:1 or such. As far as I know the axles have never been changed, bought the truck in '84, was really beat. Again, nothing time and money hasn't been able to overcome.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 01-17-2013, 01:26 PM   #2
Mike C
Mike C's Avatar
Re: 1971 K10 Rear Axle ?
At least in a Blazer, the 350 got 3.07 gears standard with 3.73 first up option in '71-'72. Look on the FRONT axle for a tag that is bolted between two of the cover bolts on passenger side of pumpkin. It should have the ratio and ring & pinion tooth count stamped into it. Assuming a PO hasn't removed it... I wish GM had used ratio tags on their axles same as Dana did.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-17-2013, 07:34 PM   #3
Ironhorse
Ironhorse's Avatar
I'll look for the tag you mentioned but doubt it is there, had this truck since
'84, been under many an hour and don't recall seeing a tag. Really don't think the gears have ever been changed since new.
Wellington, Ks
Old 01-17-2013, 11:06 PM   #4
70K10Hunter
70K10Hunter's Avatar
my 70 K10 has 3.07s up front.haven't checked the back yet.
70K10Hunter is offline   Reply With Quote
Old 01-18-2013, 07:21 AM   #5
SS Tim
SS Tim's Avatar
71 powertrain chart.
SS Tim is offline   Reply With Quote
Old 01-18-2013, 08:43 AM   #6
Ironhorse
Ironhorse's Avatar
Tim, thanks for posting that. You always have the info needed, what book or manual do you find your information in? Would be nice to have a copy if I could find one.
Wellington, Ks
Old 11-09-2013, 07:34 PM   #7
520CheyenneK10
Hey I'm doing my front/rear diffs and both have open 3.07 gearing. Is this normal to have both the same. It has a th350 tranny and the first gen. NP205 case with conventional 4x4 (warn locking hubs) front axle is a dana 44 and rear is a corporate 12 bolt. my rigs a 1973 K10 Short wide
520CheyenneK10 is offline   Reply With Quote
Old 11-09-2013, 07:43 PM   #8
Bigdav160
Bigdav160's Avatar
If they were not the same (or extremely close like 4.10 and 4.11) the vehicle would be locked up and wouldn't go anywhere.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-09-2013, 07:51 PM   #9
520CheyenneK10
Smile Re: 1971 K10 Rear Axle ?
Thanks for the explanation. Gears and ratios are not my strong points. Appreciate it
Old 11-28-2013, 12:30 AM   #10
19silverado77
Have you sold the sm465/205 setup.
19silverado77 is offline   Reply With Quote
Old 11-28-2013, 08:37 AM   #11
Ironhorse
Ironhorse's Avatar
Sorry, had the transfer and tranny sold before I even had them pulled out.
Wellington, Ks
