Old 12-02-2013, 06:51 PM   #1
Jahloha
Jahloha's Avatar
Por15 Without Complete Tear Down
Team:
Can I apply Por15 without completing a full tear down (i.e. the front and rear ends, engine cross member, etc)? Or is this just foolish?
Mahalo,
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 12-02-2013, 07:15 PM   #2
Lee H
Lee H's Avatar
Re: Por15 Without Complete Tear Down
Sure, just clean per instructions and have at it. Do what ever you can reach now and then the other parts in the future do as the opportunity presents it's self.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-02-2013, 07:47 PM   #3
JointTech
JointTech's Avatar
how will you por that stuff? Por works on bare metal. can you grind all the paint off those things while still on the truck? It also has a degreasing process where you have to wash first then apply an etch then you por. seems like a nightmare with it all still on the truck. And if you dont do the por the correct way you might as well just use rattlecan imho. it costs to much and is to nasty to work with to not get the full rust proofing benefits and/or have it peel off later.
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 12-02-2013, 07:57 PM   #4
notahybrid
Used it both ways. Obviously easier to use if the parts are out but not impossible if you are willing to lay on the floor scrape, wire brush, degrease, etc.. then start the POR process. I will say if done right it looks good and lasts.
notahybrid is offline   Reply With Quote
Old 12-03-2013, 07:49 AM   #5
gysgtc
I can tell you from experience. POR does not stick well going over existing paint.
gysgtc is offline   Reply With Quote
