Old 12-03-2013, 11:35 AM   #1
jabborabbo
jabborabbo's Avatar
Advice for removing the shoulder belt blanking plugs...
I just acquired a pair of '67 shoulder belts - I'd like to remove the plugs that have been there for the last 46 years without damaging them to the point of rendering them unusable - anyone have any suggestions?
Thanks in advance!
jabborabbo is offline   Reply With Quote
Old 12-03-2013, 12:18 PM   #2
Lee H
Lee H's Avatar
Re: Advice for removing the shoulder belt blanking plugs...
They are very brittle, as I'm sure you have guessed. I use a small flat blade screw driver and as gently as possible work around to pry out. I get them at the pick apart and usually 1 out of three break.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 12-03-2013, 12:51 PM   #3
cdowns
cdowns's Avatar
i'd spray them good with windex and use a putty knife and hold your breath while prying
Old 12-03-2013, 04:39 PM   #4
jabborabbo
jabborabbo's Avatar
Do y'all think it would be prudent to warm it up a bit with a hairdryer? I've had success doing that with old/brittle plastic hoses - it tends to make them a bit more pliable....
Also, does anyone have a picture of what they look like from the side? That could help in knowing where to press/pry....
Old 12-03-2013, 05:28 PM   #5
srvivor71
srvivor71's Avatar
I wasn't really thinking of saving mine when I removed them so i just popped them right out with a flat blade screwdriver (being careful not to scratch the paint on the roof/c-pillar). They came out easy as could be without breaking or cracking at all.
srvivor71 is offline   Reply With Quote
Old 12-03-2013, 06:03 PM   #6
Andy4639
Old member
Andy4639's Avatar
Cool Re: Advice for removing the shoulder belt blanking plugs...
I'm going to ask a dumb question I guess, why are U wanting to save them if U are putting shoulder belts in the truck. They are small plastic caps that want be worth anything once removed.
Just wondering and I would like to see the orignal shoulder belts please. How did they mount on the floor and retract.
I put a set of late model's in my years ago. I don't think I have ever seen a factory set for these trucks.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-03-2013, 06:19 PM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
I've only ever seen one set installed in person. I think you pretty much have to "buckle up" twice. If I remember right, the upper part is a buckle and there is a hanger thing to hang it above the door when not in use.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 12-03-2013, 06:35 PM   #8
FirstOwner69
FirstOwner69's Avatar
Here is a pic of only the shoulder belts. The cut off tabs and boots in the middle are spares. No retractors and buckle up twice.
FirstOwner69 is offline   Reply With Quote
Old 12-03-2013, 06:52 PM   #9
leddzepp
Moderator
leddzepp's Avatar
I have a set of originals in my truck as well. They are a pita to use to say the least!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-03-2013, 07:15 PM   #10
Lee H
Lee H's Avatar
I have the shoulder belts also, major pain to use so I just use the lap belt.
Picture of plugs.
Old 12-03-2013, 07:25 PM   #11
midniteblues
midniteblues's Avatar
whoa you got 67' shoulder belts! thats a super rare find. lets see some pics
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 12-03-2013, 08:06 PM   #12
Andy4639
Old member
Andy4639's Avatar
Wink Re: Advice for removing the shoulder belt blanking plugs...
Thanks for posting the pictures. I will stick to my late models after all the comments on them!
Old 12-03-2013, 08:53 PM   #13
jabborabbo
jabborabbo's Avatar
Not a dumb question at all - my '67 is pretty much original (see my intro thread here). I'm making a few modifications to it (gauge cluster, shoulder belts, etc.) but keeping all the original stuff so that it can be put back like it was originally so that the SPID is correct. When I get the belts installed I'll post some pictures.
Old 12-03-2013, 08:54 PM   #14
jabborabbo
jabborabbo's Avatar
Picture of plugs.
Thank you Sir!
Old 12-03-2013, 09:26 PM   #15
LockDoc
The Older Generation
LockDoc's Avatar
I think it would help to heat them up a bit. Couldn't hurt any thing. I try to save that kind of stuff too...
LockDoc
Leon
Old 12-08-2013, 04:52 PM   #16
jabborabbo
jabborabbo's Avatar
Well, I wasn't quite successful...I was hoping to find the split shown in some of the pictures Lee H posted and then push on either side while pulling it out, but mine is/was solid. I suppose the good news is that since I didn't mess up the cap I may be able to get creative with some glue and re-use it at some later date if I decide to....
Old 12-08-2013, 05:33 PM   #17
AirSpeed
AirSpeed's Avatar
I pulled out the old ugly plugs in my cab and bought new ones at the local hardware store, cost 25¢ each. Bought a few more to plug up unused holes in my firewall, they had about ten different sizes.
AirSpeed is offline   Reply With Quote
