cluthch question
I am in the process of rebuilding my daughters 66 and originally thought I would go with an automatic tranny so I threw away the clutch and flywheel. Dumb mistake, she decided she liked the idea of a 3 on the tree. I bought a new flywheel from rockauto and need to order the clutch kit. I am putting a rebuilt 350 in it so I need to know which clutch to put it in it since I am not using the original engine. 11" or 12"? how many splines? any other info would be appreciated. Truck is down to bare frame rebuilt from the ground up and I am ready to put the engine and tranny in before I mount the cab back.
Thanks |
Re: cluthch question
Should be 27 spline and probably the 10" clutch. Some take the 11" clutch
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
I think you are thinking of the rear axle spline. The clutch should be a 10t, 1 1/8"
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 |
#4 | |
i think at 27 spline that you are talking later year output spline. you can get a flywheel for either size clutch. personally i would go with the 11". little harder to slipesp if she hasn't driven a std before. there are also 2 different size ring gears depending on which starter that you are going to use ron |
What year flywheel did you use?
Yeah...27 spline output 10 spline in....sorry
Flywheel is a RHINOPAC / WORLD CAR 167654 from rockauto for a 12" clutch. I think I may have been over thinking this. looks like a 1 1/8 10t since that is all they offer. I put a 78 chevy front end underneath it and think I might have mixed up the years when looking up parts.
Does 92.00 sound about right for the kit. I haven't done a clutch in about 20 years or so. thanks guys |
![]() Join Date: Oct 2007
If you're using the stock cast iron bellhousing, I'm not sure the larger flywheel will fit. I've heard that SOME of the smaller flywheels are drilled for either the 10" or 11" clutch, but have never been able to confirm that.
You should be able to use the RHINOPAC / WORLD CAR Part # 04505 which is an 11". It may not be the correct throwout bearing in the kit so plan to buy a bearing for the year of the transmission.
I'm showing the part number to be 04502 in a 12 " clutch to match the flywheel I bought. Can I still use the smaller clutch? Is it the flywheel that may cause clearance issues or the clutch/pressure plate on a 12" clutch? Boy I wish I had saved that clutch.
I run a 168 tooth flywheel w/11" clutch in my truck w/cast iron bellhousing w/frame mounts
In Rock Autos description of the flywheel it says you can use either
Diaphragm Option; Flywheel Spec: FLAT With 11" Clutch; Flywheel Spec: FLAT With 12" Clutch, Lever Style; Flywheel Spec: FLAT
![]() Join Date: Aug 2008
It should be a 168 tooth flywheel.
Your probably good with an 11" clutch. Buy the throw out bearing to match your trans and clutch type. ie different thickness for mechanical linkages and hydraulic systems. I discovered this the hard way ![]()
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! Last edited by argonaut; 12-05-2013 at 09:40 PM. |
This is good to know because of my 4 on the floor. Im guessing its a big clutch either way.
No trees were killed to send this note but a large number of electrons were terribly inconvenienced. AKA. RABIDJOE... if you have to ask you prob don't want to know. Ive had my shots *dont worry* 1960 235 4SPD C30 |
#15 |
honestly a 10.5" clutch would hold a 350 no problems, i have a 10.5" valeo on my pontiac 462, 500 ft lbs of torque dynoed. I think in 66 327 came with 12", and others with 11". I'm just going to put a 12" on my 66 because that's what i took off. Valeo is a nice cheap street clutch, i've had good luck with them. Larger diameter the diaphragm clutch, slightly more pedal travel it takes to fully release. Likely not an issue in these trucks, they have pedal travel for days.
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
