Flat spot hesitation with hard acceleration
292 with Rochester single barrel, HEI ignition - Starts fine, idles perfect - Under hard acceleration will hit a dead flat spot for a split second - After that no problem - Carburetor is new rebuilt unit - I don't have a timing light so I can't make an accurate statement on timing - Tuned it be ear - Could this be a result of a bad vacuum advance?
Re: Flat spot hesitation with hard acceleration
These days I would strongly suggest getting an O2 sensor. So much easier to see if you have a fuel curve issue. My guess is a lean condition, although that is based largely on experience with Holly 4150's so perhaps the Rochester has other tendencies.
#3 | |
![]() Join Date: Mar 2013
Re: Flat spot hesitation when accelerating?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Could also be a lean factor. A good way to test if you truck is running rich/lean is to fire it off when cold and DON"T warm it up. Right after you fire it up drive it as hard as you can. Stop and shut off the motor and pull one of the plugs. If their black yer running rich if their like new and maybe even a slight bronze like discoloration yer running waaaaay to lean.
Thanks for the reply - I will check to see if the vacuum advance arm is moving this afternoon and let you know what I find - Also, I will also give it run and take a look at the plug.
If I have a lean condition what would my options be for dealing with it
#16876
Loaded question. It could be Quadbog, vacuum leaks, bad or incorrectly gapped plugs or wires, deteriorated fuel lines or worn out vacuum advance weights and pins among other things. I'd start by setting the timing correctly and inspect the internal workings of the distributor.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
There is an idle mixture screw on the carb...turn it clockwise till the engine starts to die(do this at operating temp) then turn clockwise till engine frees and gains max rpm, once max rpm gains turn a little more and that will richen it just a tad. But make sure the motor is at operating temp before you do any adjusting.
![]() Join Date: Oct 2005
T.J. means counter clockwise till engine gains max rpm.
This is a good suggestion. Try advanceing the timing a little. If everything else is good you may need for someone familiar with carbs to check the float level & metering rod adjustment. Most "reman" carbs are not right. |
check the float levels and accelerator pump.
#12 | |
