12-05-2013, 07:01 PM | #1 |
irritating belt squeal
hey guys,
i know everyone knows how irritating it is when you have a slipping belt. i replaced my fan/alt belt recently so its brand new, top cog. the other is a power steering only belt run directly horizontal to the crank pulley. every now and then, one of the belts will begin to squeal like crazy, louder when gas is applied! the other night it started and i couldnt stop in traffic, so i was like "to hell with it, burn it off" lol. sometimes it only happens after the truck has run and warmed up and then i stop for gas, etc where the truck is turned off and then back on. im not sure which belt it is. the power steering belt is not a top cog vbelt, but it doesnt seem worn, and not too loose either. i have heard that power steering belts need more tension than fan belts. not sure. also, for some reason, if i turn my heater on, the sqeal will sometimes start, sometimes stopping after a few seconds, sometimes not. i dont know if there is a small change in rpm that causes a belt to slip or what. all pulleys are lined up, and the top fan belt is brand new. the power steering belt is not bottomed out on the pulleys, but i did notice i could see some of the white string near the top edge. if anyone has any ideas, they are appreciated. thanks
12-05-2013, 10:21 PM | #2 |
Re: irritating belt squeal
tighten your belts
12-05-2013, 10:51 PM | #3 | |
Sam |
12-06-2013, 10:10 AM | #4 |
If it squeels when you turn on the heater fan your'e putting a load on the alt. which would make it that belt. if you start the truck and while stopped turn the steering wheel right to left, if it squeels, its the power steering belt. at least it will narrow it down as to which belt it is.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
12-06-2013, 12:06 PM | #5 |
Thanks for the replys guys. Will dig in and see what's what.
12-06-2013, 01:56 PM | #6 |
20' Daredevil (Ret)
As long as you're careful to keep fingers & clothing away from the moving bits, you can place a bar of soap against each belt on an idling engine. If the squealing stops when soap is applied, you found the culprit.
Also, make sure the pulleys are in alignment and the correct belts are used, and like Cliff said, tighten 'em.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
