Old 12-09-2013, 07:28 AM   #101
Hart_Rod
Hart_Rod's Avatar
Re: Trouble codes
Originally Posted by BR3W CITY View Post
The generator codes may be because the 04 alternator has an internal regulator, and your engine/pcm would normally use a PCM controlled regulator. It doesn't see the voltage it would be trying to control. OR you have a short on one of the wires.
The p057c code came up as an SES for failed cruise control module. I'm guessing you might have something wired off the TCC/brake switch incorrectly (lol I know you and JorgenSC have gone back and forth on diagrams for this in the other thread).
can't find anything on the p2537
Thanks, I deleted out the first 3. I think we have the TCC wiring figured out, . I don't even have the 4th one in my DTC list in HPTuners. That's odd that it would even come up.
Hart_Rod is offline   Reply With Quote
Old 12-09-2013, 02:33 PM   #102
jorgensensc
jorgensensc's Avatar
Re: Trouble codes
All I found so far, which I'm sure you have already found, was this:
OBD Code:
System:
Subsystem: P2537 Chevrolet – (ASE)
Powertrain
Vehicle Speed Control, Idle Controls, and Auxiliary Inputs
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
