#1876 |
![]() Join Date: Aug 2005
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
#1877 | |
Still Learning
good picture too. |
#1878 |
Thanks Mike. Here a bigger one. Should be able to read the description. But you guys already know that stuff and much much more
#1879 |
This is a great build. Makes me miss my Sunbeam.
#1880 |
#1881 |
Time to find the fatted cat ... er.. calf. Yea, that's what I ment.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#1882 |
Not sure if I mentioned - the floor, eng bay, trunk, and entire underside are still bare since I have a few loose ends to clean up in those areas. I'll be spraying the SPI epoxy myself and hitting the underside and wheel wells with Raptorliner within the SPI respray window.
#1883 |
Still Learning
Congrats on getter her back home. Looking forward to the next phase. You are boing to reach the 500K hit milestone soon. You might be the only builder on here with those numbers on 2 separate builds.
#1884 |
Well, I guess that's what happens when you start something and don't finish it for years ...and years
#1885 |
![]() ![]() Join Date: Jul 2002
You done yet?
#1886 |
the pollock
where's the paint! jeesh sure taking your time!. haha
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
#1887 |
Workin a graveyard shift this month and hitting the gym in the mornings after work - doesn't leave much left for wrenchin. Last weekend was full of xmas parties (thus the need for exercise
#1888 |
My welder is loaned out to a friend whose building a chump-car. Been hammer/doly'in a few little dings here and there. Nothing really pic-worthy. Working night shift makes the opportunity for making noise a bit limited. That ends in two days
![]() On of those nights when I couldn't make too much noise I dove into the engine disassembly. Got it pretty well torn down (external bolt-ons only) and cleaned. Researching finishing options for the cast aluminum now. Thinking I might have to do something like this to my intake - shaved (not black though) ![]() |
#1889 |
the pollock
gettin carried away, what's wrong with a glossy powder coat?
#1890 |
Carried away = the theme of this build! I can't have all those unused vac ports wearin rubber caps taunting me every time I open the hood. They gotta go! As far as finish, I'm leaning toward painting with Duplicolor cast coat aluminum and Eastwood diamond clear satin.
Here's a bike engine done with that combo: ![]() |
#1891 |
Have you thought about having a single stage urethane mixed to match the aluminum color you want, and adding in a little bit of flattener to knock it down from a full gloss? That way it would be a hardened paint and would be way more durable. I did a charcoal colored urethane with flattener on the block in my '64 VW (magnesium) and it's held up very well to the heat and oil over the last 2.5 years, still looks as good as the day I sprayed it. I did spray epoxy first for better adhesion.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#1892 |
That does sound ideal. I had already picked up the cast-coat aluminum some time ago. Just received the Eastwood Diamond clear yesterday. I've read nothing but good things about it, but I do realize that any paint is only as good as its foundation. I'll execute to plan this time and see how it goes.
#1893 |
Got a new toy in the shop. A stud welder.
I know there have been a lot of comments about how perfect the body was, but the blasting did reveal a few flaws here and there. Nothing major (unlike the front/right corner I already replaced). People have asked me why I didn't get the body work sorted before blasting/primer. The answer is two fold:
So I'm working small areas at a time and will re-apply epoxy once I get them as straight as I can. Here are few pics of the little bit I've done so far. These are only dents with no back-side access. A few others I've already worked with the hammers/dollies: ![]() ![]() ![]() All these dents and holes were buried in bondo! Getting to work with the stud welder: ![]() Also started prep'ing the engine for paint: ![]() ![]() ![]() ![]() ![]() |
#1894 |
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
This build has come a long way. Everything looks great. I like the looks of that Duplicolor cast coat aluminum and Eastwood diamond clear satin. I wonder how that would look on a bigblock !
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
#1895 |
I bet it would look awesome! A good clear should make it easier to keep clean too.
#1896 |
It's hard to believe I've been following this as a part of my morning coffee ritual for almost five years.
It's awesome to see her so close to the finish line, but I'm going to miss seeing what you've done to her next when she's finally on the road for good. I may have missed it, but I didn't see any posting of remounting the shift housing back onto the trannsmission. Do you have any info/pics on how you accomplished that? Keep up the excellent work, you help to motivate me in my substantially less enthusiatic build. |
#1897 |
Still Learning
Very nice progress on the Beam. I have one of those stud pullers in my shop. (borrowed from a good friend). They are a life saver on body repair. A must have! congrats
#1898 |
There's 1,500 of the 4XX,XXX views!
#1899 | |||
![]() Quote:
![]() Hah, and probably 66% of them were met with disappointment ![]() |
#1900 |
Love my Stud Gun. Great for making heat shrinks if you're not confident in your torch abilities (like me). This thread never disappoints. Whatever gets it on the road and the Tahoe up to bat! Damn, I love that truck.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
