Old 12-09-2013, 07:39 PM   #1
1986brownjl
electric choke question
I have a 86 chevy k10 with a quadrajet. the blue wire that connects to the electric choke do it suppose to have power when the ignition is on or how does that work?
1986brownjl is offline   Reply With Quote
Old 12-09-2013, 08:07 PM   #2
geezer#99
geezer#99's Avatar
Re: electric choke question
With the key in the run position you should have 12v to the wire.
geezer#99 is online now   Reply With Quote
Old 12-09-2013, 08:20 PM   #3
ray_mcavoy
It is also wired through an oil pressure switch so the choke only receives power when the engine is actually running ... not just with the key on.
There is a pink wire with a white stripe that is powered from the "CHOKE" fuse. That wire should be live whenever the key is on. It connects to one terminal on the oil pressure switch. The blue wire that feeds power on to the choke connects to the other terminal on the pressure switch. Note: this oil pressure switch is not the sending unit for the oil pressure gauge ... that's a separate part.
ray_mcavoy is offline   Reply With Quote
Old 12-09-2013, 09:16 PM   #4
1986brownjl
thanks guys
