Old 12-10-2013, 05:48 PM   #1
slowtruck
67-68 side trim
I've been looking at doing the factory 67-68 side trim on my 67 and been looking at picking up used parts, but what I need to know before I start spending money on the used stuff is. Did they come with screw holes or is the ones I've seen with them just something that someone did to hold it to the truck when a clip broke?
slowtruck is offline   Reply With Quote
Old 12-10-2013, 07:18 PM   #2
nobolt
nobolt's Avatar
Re: 67-68 side trim
ask DaHos....I believe he could say 100%.
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 12-10-2013, 08:44 PM   #3
Hoffa
Hoffa's Avatar
Re: 67-68 side trim
They all came with hidden clips. However after the first clip failure or reprint, I've seen black sheetmetal screws in the black strip to replace the clips.
68 Chev SWB 2WD w/'95 LT1, 6spd, 4:56, 17" whls - family owned since 1973.
70 GMC LWB 4WD w/RAMJET 350, 4spd, 4inch lift, 33" tires, Warn Winch
72 Chev Blazer CST, 350, TH350, 4WD, factory A/C, tilt, radio delete, 77K miles, orig. paint/interior
Hoffa is offline   Reply With Quote
Old 12-10-2013, 09:05 PM   #4
slowtruck
Re: 67-68 side trim
So this is no good then?
http://www.ebay.com/itm/67-68-CHEVY-...3de2c0&vxp=mtr
Old 12-10-2013, 09:14 PM   #5
Elliot949
Elliot949's Avatar
Re: 67-68 side trim
By the time you piece together a Used set of these you probably could go to Mar-K and get a complete new set... There moldings are the only ones made here in the USA and are stamped from the original GM molds... MAR-K makes them in their Oklahoma Facility... Mike Loshes "Cloud 9" has a set on it and I have a set sitting in my Garage to go on my 67 Build...
Elliot949 is offline   Reply With Quote
Old 12-10-2013, 11:20 PM   #6
Hoffa
Hoffa's Avatar
Re: 67-68 side trim
I don't know what look you are shooting for slowtruck. If you are looking for a slightly used look, you could lay some black tape over the hole. You could also put a screw there too. It's really up to you.
Old 12-10-2013, 11:32 PM   #7
slowtruck
Re: 67-68 side trim
I'm building a driver, but don't want to be putting screws/tape on one side and not the other side. I will just keep looking for them without any holes and if I can't put together a set I will look into getting a new set.
Old 12-11-2013, 09:13 AM   #8
Sammy
Re: 67-68 side trim
Good Luck on your search..the cost as you already know is what makes most of them disappear on builds. 3M trim double sided tape is a good product available at any decent paint shop, a good alternative.
A few years ago I seen a truck leave a salvage yard with a flat bed truck loaded to the sky in nothing but stainless trim going to a recycle yard. Afraid most of it was 50's, 60's type trim.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
